VVC Inlet Manifold
Rovernut
VVC Inlet Manifold
#1 Post by Rovernut » Fri Dec 30, 2016 9:19 am
I am still being plagued with coolant loss on my 416 Tourer. :sad
Its losing about a pint a week now with no sign of external or internal leakage. Pressure test showed nothing, but early morning exhaust "steam" is excessive.
As it had a head gasket fitted twelve months ago I am planning to try a VVC type manifold before removing the head again.
I understand there are two types.. one marked vvc and the other plain.
Which one should I source?
Chris
Re: VVC Inlet Manifold
#2 Post by RoverRevival » Fri Dec 30, 2016 10:01 am
As you are not a million miles from me, do you want to pop up and i'll have a look over it.
:cool
25 Streetwise 54k
620 SLI Honda 60k
& C3
Rovernut
#3 Post by Rovernut » Fri Dec 30, 2016 10:32 am
Very kind of you.
When is convenient?
Chris
#4 Post by RoverRevival » Fri Dec 30, 2016 1:05 pm
anytime after 10:00 :cool
pm for address
25 Streetwise 54k
620 SLI Honda 60k
& C3
#5 Post by RoverRevival » Tue Jan 03, 2017 9:45 pm
Chris visited the holy chapel today and luckily stopped him wasting time on needless fixes.
Far to many mechanics diagnosing HGF and just swapping gaskets rather than finding out what caused the problem in the first place.
Stunning car (when washed) and grea to chat with.
Another convert :angel
25 Streetwise 54k
620 SLI Honda 60k
& C3
#6 Post by GTiJohn » Tue Jan 03, 2017 9:50 pm
1234dist wrote:Chris visited the holy chapel today and luckily stopped him wasting time on needless fixes.
Stunning car (when washed) and great to chat with.
You're our kinda guy :clapping
#7 Post by crepello » Tue Jan 03, 2017 10:01 pm
1234dist wrote:Far too many mechanics diagnosing HGF and just swapping gaskets rather than finding out what caused the problem in the first place.
So what did you diagnose, or should the verb be 'divine' ?
Technical Advisor
#8 Post by E_T_V » Tue Jan 03, 2017 10:10 pm
leaky manifold gasket?
#9 Post by RoverRevival » Wed Jan 04, 2017 6:28 am
Unfortunately, after hearing what had been done previously i suspect its dropped liner on one of the pistons and previous gaskets being used without the saver shim. now wrong gasket as head has been skimmed numerous times, so i suspect that the reason for the excessive water consumption is relative to water getting in via the fire ring on the dropped cylinder which may be as simple as getting it shimmed (as a bodge).
The if it was me solution was buy another engine and rebuild and uprate it to n-series spec and when done drop it in but that sits in the £800-1K mark.
Next option, just drop another engine in.
and final option, get the liners reset in the original engine.
25 Streetwise 54k
620 SLI Honda 60k
& C3
#10 Post by 961tat » Wed Jan 04, 2017 8:05 pm
well if your looking at another engine i bought a 1998 cab a few weeks ago
body is rough , but i got because it had a 8 month old hood on it , so i could
replace mind and have some spares .
its a 1.6 and done 42000 from new i dove it back from scotland and been using for
the last 4 weeks daily ,it is sweet :) no tapping and no water lost starts first time
and heater is nice and hot and still in the car if you wanted to here her running .
ps if any one else wants any spares for a cab just let me know want you want
bearing in mind that i am using hood and gearbox .
car is near forton services M6 between preston and lancaster .
961tat :) :)
Rovernut
#11 Post by Rovernut » Thu Jan 05, 2017 1:57 pm
I would be interested in the engine.
PM sent
Chris
Rovernut
#12 Post by Rovernut » Fri Jan 06, 2017 11:53 pm
[img][http://s39.photobucket.com/user/Rovernu ... ml?o=0/img]
Trying to post a picture....
#13 Post by RoverRevival » Sat Jan 07, 2017 12:39 am
mmmmmm smokey
25 Streetwise 54k
620 SLI Honda 60k
& C3
Rovernut
#14 Post by Rovernut » Sat Jan 07, 2017 9:15 am
Thanks Craig!
My very own Stanley Steamer. Its running well though... must be the water injection! :laughing2
