Screeching belt on 214i
#1 Post by Hammond » Thu Jan 05, 2017 9:13 pm
No noise when it's idle but one of the belts is screeching occasionally when changing through the gears.
It's had a new timing belt in 2014 around 15,000 miles ago.
What else should I be looking for?
416Si 'Ocean Blue' (R426 BFC)
414Si 'Ocean Blue' (R478 AHJ)
414SEi 'Bermuda Blue' (V52 VFL)
416GTi Auto 'Diamond White' (J668 GRP)
Re: Screeching belt on 214i
#2 Post by GTiJohn » Thu Jan 05, 2017 9:36 pm
Have you got power steering?
If not then it can only be the alternator.
For the former manoeuvre it onto full-lock , for the latter put on as much electrical load as possible - HRW, lights etc
Re: Changing timing belt
#3 Post by 961tat » Thu Jan 05, 2017 9:48 pm
belts power steering and alternator ( check if they are cracking up etc ) timing belt , water pump and tensioner and you'll better better off with a cam locking tool ( draper on ebay ) straightforward job really.
:) :) :D
#4 Post by Hammond » Thu Jan 05, 2017 9:50 pm
Yes to power steering and meant to say that the alternator belt was also changed in 2014.
But will try both of those independently.
Cheers
#5 Post by Mr Teddy Bear » Fri Jan 06, 2017 3:34 pm
Putting chalk on the pully is another way of seeing if that particular belt is slipping. Pattern belts around in the 90's were renowned for this, sometimes sold by the dealers themselves; Ford In Chesterfield and Nissan in Nottm from memory. :mad
It will be a vee shaped belt, not a toothed timing belt; the chalk gives the belt more purchase in the pully.
