1996 216 Cabriolet - Heater
rbosworth2016
#1 Post by rbosworth2016 » Thu Mar 22, 2018 11:56 am
Is there any way to adjust the amount of air blown into the passenger and driver footwells? Our Cabriolet blows vastly more air into the drivers footwell compared with the passenger footwell. The drivers feet are cooked and the passengers are slightly warmed.
Re: 1996 216 Cabriolet - Heater
#2 Post by Mr Teddy Bear » Fri Mar 23, 2018 8:04 pm
You need to pick up a Haynes Manual from Ebay. If the lever [that works the flap] has come loose from it's Bowden Cable that means taking the dash apart. Before doing that [if the car is a keeper at least fro the next couple of years] I would flush and change the coolant. It doesn't last for ever!
#3 Post by 1234dist » Sat Mar 24, 2018 7:16 am
as above, there may be an obstruction to one of the flaps and like water, air takes the path of least resistance. In your case cold ankles for your passenger :)
#4 Post by ROVER-25X » Sat Mar 24, 2018 10:39 pm
Nowt worse than obstructed flaps. :blink
ROVER-25X (2001 1.4 ROVER 25)
ASTRA TwinTop 1.9CDTi
