Where is the location of ECU on Rover 200 mk2 r8?
ramboiavzl
#1 Post by ramboiavzl » Mon Apr 16, 2018 8:43 pm
Where is the location of ECU on Rover 200 mk2 r8 and how to check if ECU have some ECU fault codes errors?
Re: Where is the location of ECU on Rover 200 mk2 r8?
#2 Post by Mr Teddy Bear » Mon Apr 16, 2018 9:02 pm
It depends on which engine your R8 is fitted with; the Honda has the ECU under the carpet in the front passenger footwell. The K & M/T Series it sit's next to the battery on it's side.
ramboiavzl
#3 Post by ramboiavzl » Mon Apr 16, 2018 9:23 pm
My engine reference is d16a9 and the car model is the Rover 216 gti
#4 Post by 1234dist » Mon Apr 16, 2018 9:32 pm
as above, passenger footwell, under the carpet
#5 Post by GTiJohn » Mon Apr 16, 2018 10:23 pm
And the fault codes are still here - https://honda-tech.com/forums/honda-crx ... t-2568405/
