Cambelt snapped
Thetwisted
Cambelt snapped
#1 Post by Thetwisted » Tue Mar 05, 2019 5:58 pm
Hi people looking for a bit of advise.
So the belt snapped on my 216 dohc Honda engine (94), ive only owned it a few months and im gutted, i read somewhere something about non interference engines, is there any hope of sticking another belt on and off she goes or is it a strip down mega money job?
Cheers
Jay
Re: Cambelt snapped
#2 Post by 1234dist » Tue Mar 05, 2019 6:33 pm
Good news, off memory i'm sure the honda engine isn't an impact engine so should just be a case of new belt away you go.
Re: Cambelt snapped
#3 Post by Mr Teddy Bear » Tue Mar 05, 2019 6:34 pm
Were you driving when it let go? did it just stop or was there a loud bang and the sound of poppet valve hitting piston crown? :scared
I have the Honda D16 engine workshop manual some where, I will try to dig out later tonight.
Re: Cambelt snapped
#4 Post by richard moss » Tue Mar 05, 2019 6:51 pm
It's certainly worth the cost of the belt to give it a go
Thetwisted
Re: Cambelt snapped
#5 Post by Thetwisted » Tue Mar 05, 2019 7:13 pm
Thanks for the replys.
I was doing 70mph & it just died no bangs or pops.
Re: Cambelt snapped
#6 Post by 1234dist » Tue Mar 05, 2019 7:18 pm
i'm just doing some googling and its not looking good i'm afraid.
time to start searching ebay for engines
Re: Cambelt snapped
#7 Post by Mr Teddy Bear » Tue Mar 05, 2019 7:47 pm
Manual is no help I'm afraid.
Re: Cambelt snapped
#8 Post by crepello » Tue Mar 05, 2019 8:06 pm
... well he is from Barcelona.
Re: Cambelt snapped
#9 Post by Mr Teddy Bear » Tue Mar 05, 2019 8:33 pm
:tt2
Ha I saw what you did there!
Re: Cambelt snapped
#10 Post by Johnny 216GSi » Tue Mar 05, 2019 8:43 pm
Worth a new belt with CORRECT alignment of both cam shafts and the crank shaft.
Other than that, it's head off and have a look. Not a small job and I'd only really entrust it to a decent engine specialist who does honest, fair work for fair prices. Even if that was just a diagnosis and estimate type thing.
Not sure how easy repair parts are to get for the DOHC - it might be that you have to approach a specialist engine rebuilder to be able to get hold of the parts.
In contrast, the SOHC engine is basically a D16A6, which was in the Honda CRX MK2 88-91. Ebay is full of off-the-shelf rebuild kits that contain everything including valves and pistons from the US. None of the parts fit a DOHC engine and I'm not sure where you'd go to find them. The D16A8/A9 WAS also used in the CRX, but it wasn't experimented with as much as the SOHC and I'm not sure the rebuild kits exist. An engine rebuilder might be able to get you a parts list of what you need and I think they have some privileged agreement with the manufacturers by which they can more easily buy what's needed.
Having said all of that.. I've found a full set of valves, springs and other hardware from a 47K D16A9 engine for £45 posted: https://www.ebay.co.uk/itm/Honda-CRX-16 ... 3135822840
I'll have a look later and see if I can get you some part codes and equivalences... You'd potentially need pistons and valve seals too...
Re: Cambelt snapped
#11 Post by crepello » Tue Mar 05, 2019 9:28 pm
Would a look down the plug bores with an endoscope device save taking the head off only to find fortune had been smiling?
Re: Cambelt snapped
#12 Post by 961tat » Tue Mar 05, 2019 10:08 pm
Remember this happening a many years ago to someone , the cause of the failure was water pump not the belt , The water pump seizes and that strips the teeth on belt.
so examine belt for striped teeth , i always change the pump when doing a cambelt change ( maybe because i run a alfa ).
use the endoscope device if you can good idea :clapping , fit a new belt and turn it over slowly by hand (plugs out) to see if you can feel any interference or obstruction.
the guy i no whose belt went got a way with it :clapping , so fingers cross and all the best and if you need a haynes manual i have got one you can have .
hope all goes well :D
Re: Cambelt snapped
#13 Post by Johnny 216GSi » Tue Mar 05, 2019 11:16 pm
^^^ Very good advice. Wish I'd supplied it.
PS. Now I know why garages insist on changing the water pump when they change a cam belt.
Last edited by Johnny 216GSi on Wed Mar 06, 2019 12:49 am, edited 1 time in total.
Re: Cambelt snapped
#14 Post by Johnny 216GSi » Wed Mar 06, 2019 12:43 am
For the D16A8 engine:
Pistons
13010-P29-000 Piston set (Nominal/standard size)
13020-P29-000 Piston set (Oversized 0.25)
13030-P29-000 Piston set (Oversized 0.5)
(They're basically Honda "P29" pistons which you can look up on Ebay)
Piston ring sets
13011-PM6-003 Ring set standard (Manufacturer: Teikoku)
13011-PM6-004 Ring set standard (Manufacturer: Riken)
13021-PM6-003 Ring set 0.25 oversized (Manufacturer: Teikoku)
13021-PM6-004 Ring set 0.25 oversized (Manufacturer: Riken)
13031-PM6-003 Ring set 0.5 oversized (Manufacturer: Teikoku)
13031-PM6-004 Ring set 0.5 oversized (Manufacturer: Riken)
Valves
14711-PG6-000 (intake)
14721-PG6-000 (exhaust)
Valve seals
12210-PT2-003 Valve Stem seal A (Manufacturer: Arai)
12210-PT2-004 Valve stem seal A (Manufacturer: Nok)
12211-PT2-003 Valve Stem seal B (Manufacturer: Arai)
12211-PT2-004 Valve stem seal B (Manufacturer: Nok)
There are probably a few more parts you might need, but this should help an Ebay search.
Re: Cambelt snapped
#15 Post by Johnny 216GSi » Wed Mar 06, 2019 12:57 am
Not sure why I bothered looking up some of the Honda part codes now...
Rover part codes:
Pistons: LFL10258 (in stock at Xpart)
Ring set: FDU1305 (in stock at Xpart)
Inlet valves: FDU1484 (in stock at Xpart)
Exhaust valves: FDU1486 (only 1 at Damen and Kroes in the Netherlands)
Inlet valve seals: LUB100390 (AE Wilcox in Gloucester has 1, Damen and Kroes have 21 in stock)
Exhaust valve seals: LUB100380 (AE Wilcox has 11, Damen and Kroes have 13)
