Door handle for front left door exterior 216i Cabrio needed
ahorn142
#1 Post by ahorn142 » Sun Aug 11, 2019 4:54 pm
Hello,
I urgently need a door handle, left front door exterior, for a Rover 216i Convertible XW, 1993.
Can´t open the door from outside anymore, only from inside. Obviously, I guess, something is broken.
Part number is probably CXB10111LML.
best regards
ahorn142
Kriss707
Re: Door handle for front left door exterior 216i Cabrio needed
#2 Post by Kriss707 » Sun Aug 11, 2019 10:58 pm
Hi,
It may not be broken, there is a retainer clip that holds the rod that operates the latch assembly that sometimes comes adrift.
Remove the door card & you will be able to see, if so you just relocate the rod and push the clip back over.
Where are you to?
#3 Post by 961tat » Mon Aug 12, 2019 1:35 pm
If you have no luck with the rod and clip I have a one , pm me if you want .
ahorn142
#4 Post by ahorn142 » Tue Aug 13, 2019 5:52 pm
I have a very capable workshop.They told me after inspection that I need a new handle, because the old one is not repairable. :cursing
