216 Cabriolet passenger windscreen wiper failed
rbosworth2016
#1 Post by rbosworth2016 » Sat Dec 07, 2019 10:17 am
The passenger side windscreen wiper on my 216 Cabriolet has failed. It does not move when the wiper motor runs (but the driver side works OK). I can move the passenger wiper easily by hand. When I do this the nut clamping it to the drive shaft does not move. I suspect the splines locking the wiper to the shaft must be smoothed flat. Any ideas what bits I might need to repair this.
Richard
Re: 216 Cabriolet passenger windscreen wiper failed
#2 Post by crepello » Sat Dec 07, 2019 11:49 am
First move would be to take the arm off, clean out any debris and reassemble.
If that failed, then a new arm would be simplest - if you can find one!
It's unlikely that the spindle is worn, since that is steel, and the arm is die cast alloy.
#3 Post by 961tat » Sun Dec 08, 2019 10:08 am
If you need wiper arm I have spares ones :D
#4 Post by ROVER-25X » Sun Dec 08, 2019 5:46 pm
You have enough spares to build a spare car. :laughing2
