Machine gun type clicking from Dizzy
tonyinbeds
#1 Post by tonyinbeds » Fri Aug 21, 2020 2:26 pm
A new one for me...
When I crank it over to start it makes a machine gun repetitive clicking noise.
Initial thoughts were fuel pump leak and refilling as it eventually started after 4 goes.
Just cranked it over and filmed it and clearly coming from the Dizzy.
Any ideas or links to previous threads on this all welcome. :)
Cheers
Tony
1995 Rover 216 16V (Honda Engine D16A6)
Beds/Northants
Re: Machine gun type clicking from Dizzy
#2 Post by RoverRevival » Fri Aug 21, 2020 2:43 pm
Battery low charge or failing.
25 Streetwise 54k
25 IL 36k
216 ronda coupe
620 SLI Honda 60k
& C3
tonyinbeds
#3 Post by tonyinbeds » Fri Aug 21, 2020 4:09 pm
Thanks, just been and given it an inspection and the starter looks liek the source of the noise and not dizzy.
Cheers
Tony
Beds/Northants
#4 Post by RoverRevival » Fri Aug 21, 2020 4:10 pm
Charge it first or jump it :wink3
25 Streetwise 54k
25 IL 36k
216 ronda coupe
620 SLI Honda 60k
& C3
tonyinbeds
#5 Post by tonyinbeds » Fri Aug 21, 2020 4:40 pm
Cheers
Tony
Beds/Northants
#6 Post by Johnny 216GSi » Fri Aug 21, 2020 5:27 pm
Are you sure it's coming from the dizzy or starter motor? If you can hear it quite loudly inside the car, it's more likely the main relay dropping out as in - it engages, the starter fires, the battery is dead so the battery voltage drops, then the main relay clicks out and the process starts again - so you get a fast quite loud clicking inside the car. Had it a few times - new battery required, or make sure yours is capable of holding a charge and charge it.
tonyinbeds
#7 Post by tonyinbeds » Fri Aug 21, 2020 7:16 pm
Thanks, I'll charge the battery anyway but I put my hand on the starter while someone else turned it over and could feel the vibration. I was misled earlier as doing it by myself and saw the dizzy move. Noise is not in the car. :)
Cheers
Tony
Beds/Northants
#8 Post by crepello » Sat Aug 22, 2020 12:01 am
The vibration you felt was probably the starter solenoid failing to stay engaged because the starter motor sucked enough from the battery to drop the voltage, much as surmised earlier with the relay. The relay powers the solenoid, the solenoid operates the motor power contact and shifts the pinion into engagement with the flywheel ring gear.
#9 Post by Paul_1978_yorks » Sat Aug 22, 2020 7:25 am
Do you have a multimeter? Take some readings from the battery and let us know.
1996-N Charcoal 214 SEi (rolling project)
214 SEi x3, 216 SLi, 216 Cabriolet, 416 GSi, 25, 45, 75
tonyinbeds
#10 Post by tonyinbeds » Sun Aug 23, 2020 11:40 am
No I need to get a mm.
I charged the battery all day yesterday up to 14V and still clicking so excludes battery.
Just researching a bit more and found this... https://youtu.be/xgoqd9myj38 so not too difficult.
Also this https://youtu.be/tx4H5ttxbJ0 - I will go and check this first before taking SM off.
Cheers
Tony
Beds/Northants
tonyinbeds
#11 Post by tonyinbeds » Sun Aug 23, 2020 12:04 pm
found this one too... https://youtu.be/9LphUnzoIGs?t=347
Seems like a good way to prevent wasted effort.
Does anyone recommend a good make of Multi Meter please?
Cheers
Tony
Beds/Northants
tonyinbeds
#12 Post by tonyinbeds » Sun Aug 23, 2020 5:35 pm
Got there, it needs a new battery.
Cheers eveyone for help. :clapping
Cheers
Tony
Beds/Northants
#13 Post by RoverRevival » Sun Aug 23, 2020 5:43 pm
1st reply.... :angel :wink3
25 Streetwise 54k
25 IL 36k
216 ronda coupe
620 SLI Honda 60k
& C3
#14 Post by Paul_1978_yorks » Sun Aug 23, 2020 8:45 pm
I think they’ll all be much of a muchness. I don’t think mine was particularly expensive but it works well and does the job.
tonyinbeds
#15 Post by tonyinbeds » Mon Aug 24, 2020 8:27 am
Cheers, went for a £8.99 one off ebay in the end.
Cheers
Tony
Beds/Northants
