Late Rover 25 Fob Programming
cybercontroller
#1 Post by cybercontroller » Wed Sep 16, 2020 11:36 am
Not able to find anything specifically so asking the questions.
Two keys and fobs came with the 2005 Rover 25, One fob works fine abut the other does not. The seller told me he had changed the battery but the unlock and turning off the immobiliser button did not work. I have seen a refurbishment service on ebay and wanted to check how good they were as that would seem to be the way forward on that.
I have also since acquired a second hand fob and wondered how easy it is to get reprogrammed. It says 433MHz on the back
Re: Late Rover 25 Fob Programming
#2 Post by RoverRevival » Wed Sep 16, 2020 11:54 am
As far as I’m aware my Pscan can do them but don’t quote me.
25 Streetwise 54k
620 SLI Honda 60k
& C3
Roverlike
#3 Post by Roverlike » Wed Sep 16, 2020 1:20 pm
Second hand Pektron fobs are useless as you cannot program them to your car. In order to program Pektron fob it must be new fob with bar code included with the fob. Then this bar code can be entered within diagnostic tool like pscan (yes pscan can program Pektron fobs) in order for your Pektron alarm system (or BCU or SCU however you would like to call it) to recognise new fob.
Regarding refurbishment of Pektron fob it can be used if microswitches or plastic case are worn. However you must be sure your fob was working previously. You say that unlock button does not work, but does lock button work on your second fob?
cybercontroller
#4 Post by cybercontroller » Wed Sep 16, 2020 2:19 pm
Thanks for the answer, the second hand one is only good for parts but the second one that cam with the car I was told worked apart from the unlock so it would be worth getting refurbed.
Russnp
#5 Post by Russnp » Sat Sep 19, 2020 10:58 am
I cant find the details at the moment but there is a chap on the south coast that does them mail order.
Problem is you have to send the BCU too. If the car has aircon it means a degas to remove it.
Luckily for me the previous owner of mine had moved the BCU to prevent water ingress and it was a five minute job to remove
98 Rover Coupe VVC
99 MGF VVC
03 ZT 135
03 ZR 115 TD
15 MG3 , partners car
Off the road at present
Maestro van , British Rail
Maestro EFi - in body shop
Metro Turbo
#6 Post by itcaptainslow » Sat Sep 19, 2020 1:45 pm
You can just wiggle the BCU out without degassing the air con-you just need to unbolt the pipes in the engine bay. It’s tight, but do-able.
Rover 214SEI
Lotus Elise S
Roverlike
#7 Post by Roverlike » Sat Sep 19, 2020 4:36 pm
You mean the Paul Brown aka Technozen at https://www.technozen-electronics.co.uk ... formation/
Russnp
#8 Post by Russnp » Sat Sep 19, 2020 8:10 pm
That's him!
Great service, I needed a horn relay changing in the BCU so I got a fob aswell. He actually supplies replacement fobs , they are slightly different to the pektron fobs but it works well
I didn't realise you can get the BCU out by moving the pipes , good tip cheers
Do the later R8 coupes have a BCU?
98 Rover Coupe VVC
99 MGF VVC
03 ZT 135
03 ZR 115 TD
Metro Turbo
Roverlike
#9 Post by Roverlike » Sat Sep 19, 2020 9:01 pm
Pektron BCUs started to deploy in 2003, so no late R8 coupes do not have BCU.
#10 Post by 961tat » Sat Sep 19, 2020 9:13 pm
I can highly recommend him sent him two key fobs 5as and ecu none of the above matched now all working , good service and quick :thumbup :thumbup
#11 Post by 220 GSi turbo » Sat Sep 19, 2020 9:50 pm
Another thumbs up for Paul (Technozen) from me too :thumbup1
Daily: ZR Trophy TD
#12 Post by itcaptainslow » Sat Sep 19, 2020 10:21 pm
And another from me-he repaired a BCU for me quickly and expertly.
Rover 214SEI
Lotus Elise S
cybercontroller
#13 Post by cybercontroller » Thu Sep 24, 2020 5:57 pm
Thank you. That could be most useful.
cybercontroller
#14 Post by cybercontroller » Fri Oct 02, 2020 9:56 am
Happily I seem to have got the second fob working to a point but I suspect the buttons area bit stiff in the case.
Would this
https://www.ebay.co.uk/itm/MG-ZR-Rover- ... Swu9dfJ~1W
Be a good option? Can get the blade cut and have a more robust case for the remote part.
Russnp
#15 Post by Russnp » Sat Oct 03, 2020 8:17 pm
You can get replacement cases for the remotes
98 Rover Coupe VVC
99 MGF VVC
03 ZT 135
03 ZR 115 TD
Metro Turbo
