Rear Spring - Rubber Ring - Need Advice
JEASPEKE
#1 Post by JEASPEKE » Mon Jul 05, 2021 4:56 pm
After MOT in June (passed) this rubber fell out from above the offside spring top mounting. :blink
What is the best way to replace it, can you get these parts? Or is it part of the top mounting repair plate that I see you can get online?
(The car is a 1990 216GTi, 5 Door, DOHC)
I guess would need to do both sides and may as well change dampers while I am in there
Bet Craig knows...
Re: Rear Spring - Rubber Ring - Need Advice
#2 Post by RoverRevival » Mon Jul 05, 2021 6:48 pm
Looks more like a spring cap, (wraps around the spring to save damage when fitting). Personally I wouldn’t worry about it, but if you want to send me a pic of your entire strut I’ll see if anything looks out of place.
My numbers all over the tinterweb or I can come see on Sunday if at gaydon.
Not exactly easy to judge scale off that pic.
Plenty of parts for sale @ www.roverrevival.co.uk
JEASPEKE
#3 Post by JEASPEKE » Mon Jul 05, 2021 7:08 pm
Thanks, Craig, yes it did look like it was just placed snug around the top coil of the spring.
No comment on it by the MOT'er; maybe he wiggled it.
It is about 4 ins in diameter, same size as the spring.
See you at Gaydon, unless it pours down!.
John
#4 Post by GTiJohn » Tue Jul 06, 2021 11:34 am
It prevent metal-to-metal contact between the top coil of the spring and the spring pan.
Sounds like a good candidate for 3D printing if there are no NOS parts available :)
JEASPEKE
#5 Post by JEASPEKE » Tue Jul 06, 2021 5:42 pm
Thanks John
Might be able to use a rubber hose cut along its length.
Good excuse to replace the rear dampers as well.
See you Sunday
