rear drum to disc conversion
JOHNDQ
Re: rear drum to disc conversion
#16 Post by JOHNDQ » Thu Feb 08, 2018 11:43 pm
If you have discs on a Escort you were probably using the Focus or Sierra calipers which were one of the worse ever made, the Escort if fitted with discs (non Cosworth) had brake shoes inside the disc which will lock wheels at any speed :laughing2 on another note my ZS and ZR have discs on back and the handbrake is really good, heard the car on the burn out strip and Santa Pod no trouble :laughing as shown at 4:20 against the Mk7 Golf GTI :wink3
https://youtu.be/y3QTSaii_Qk
pkronic
#17 Post by pkronic » Fri Feb 09, 2018 1:54 pm
1234dist wrote:
Thu Feb 08, 2018 6:58 pm
your call :laughing2
i think they look pretty, not arsed how they work :laughing2
http://218vvccabriolet.blogspot.co.uk/2 ... rsion.html
*laughs* they doo look pretty but majority of changes i make are for performance *laughs*
#18 Post by 961tat » Fri Feb 09, 2018 6:38 pm
you can also use rear trailing arm , disc etc of a rover 45 . :) :) :) :)
#19 Post by RoverRevival » Fri Feb 09, 2018 7:10 pm
do the handbrake cables fit too from a 45?
45 1.8 auto Connie 50k
25 Streetwise 54k
620 SLI Honda 60k
Yaris & C3
#20 Post by 961tat » Sat Feb 10, 2018 8:04 am
Good point , will up date when I have done this , but I know the rest fits , the front end on the 45 is not the same .😀
Kriss707
#21 Post by Kriss707 » Sun Apr 14, 2019 7:29 pm
I know it's an old thread, it's just info for any one else planning it.
Did this conversion this weekend, took about 2 hours.
Used the complete Arm set up from a 1994 Cabbie, including all the links & handbrake cables. Took the liberty of upgrading the trailing arm bushes for Ploy bushes, which just push in.
Very pleased with the results, & they look sooooo much better than the drums.
