Vented Disc Upgrade
Kriss707
Vented Disc Upgrade
#1 Post by Kriss707 » Sun Oct 28, 2018 9:01 pm
This is probably an easy job, but I would like a bit of info before getting started.
Father-in-Law wants to upgrade his 214 Cabbie from 238mm solid discs to 216 262mm vented discs.
Is the actual caliper the same & will I get away with just changing the discs and caliper mounting bracket from a 216 ?
Thanks in advance.
Julesmat50
Re: Vented Disc Upgrade
#2 Post by Julesmat50 » Mon Oct 29, 2018 12:35 am
I am pretty sure you are not going to be able to use any of the main components, the solid discs have a narrower gap between the piston and the caliper mounting points and a vented disc will simply foul. A vented disc is close to twice the thickness of a solid one, so If he wants to swap to vented discs, he will need to change all 3 components, the disc, caliper and carrier.
#3 Post by JOHNDQ » Mon Oct 29, 2018 1:27 pm
May need to change the hubs too
#4 Post by Johnny 216GSi » Mon Oct 29, 2018 2:22 pm
The hubs (knuckles) are different on a 214. However, the approach Rover took with the knuckles and front ARB was to keep the datums the same and increase metal thickness to make everything stiffer. I think (and it's only a "think" - not 100% sure at all) 214 knuckles are just a "spindlier" version of 216 knuckles., so the mounting faces are the same. Maybe someone else can confirm this?
Having said that, the calliper carriers AND callipers are DEFINITELY different - you need to account for purchasing both to do the disc upgrade , at the very least.
216 knuckles are NLA if they are different, so you'd need to find a 216 donor car - this would also serve as a source of callipers and carriers. To be on the safe side, I'd say "take the lot" off a 216 and it will bolt onto the 214.
Kriss707
#5 Post by Kriss707 » Mon Oct 29, 2018 6:14 pm
Thanks chaps,
I recently stripped a 216 ( that's why he asked ) luckily I kept the front struts complete. Woz hoping it would be just a disc & caliper carrier swap.
Oh well looks like a complete strut swap then.
#6 Post by GTiJohn » Tue Oct 30, 2018 6:18 am
You're correct - the solid disc knuckle is a different forging to the vented disc knuckle - so Kris is doing the upgrade in the simplist way.
To retain brake balance under harder braking the brake PCRV (Pressure Concious Reducion Valve) from the 216 should also be transferred across.
#7 Post by 961tat » Sun Nov 04, 2018 8:02 pm
Done this mod and the centre of the hub to the caliper bolt holes are a different in length , 216 hubs the way to go .
As any one fitted rear disc on a cabby ? Got all the bit to do this I think , rear arms of a 45 etc just wondering if there were any issues . ie hand brake cable .
#8 Post by RoverRevival » Sun Nov 04, 2018 9:39 pm
i have discs on the back of my cabby
45 1.8 auto Connie 50k
25 Streetwise 54k
620 SLI Honda 60k
Yaris & C3
Kriss707
#9 Post by Kriss707 » Tue Nov 06, 2018 7:37 pm
I am planning to do the rear disc brake conversion on my cabby in the spring. I removed the units complete from the donor car. Yes the handbrake cables are different on the disc to the drum rears, so you will need them too.
