Hybrid turbo
Ktm300exc
Hybrid turbo
#1 Post by Ktm300exc » Sat Mar 02, 2019 7:38 pm
Hi all anyone on here ever put a bigger turbo on a 2.0 sdi??
Re: Hybrid turbo
#2 Post by RoverRevival » Sat Mar 02, 2019 8:10 pm
You don’t normally buy a deseisel for its performance upgrades. If it has an odd port I’d be interested in seeing if I could map it but I don’t see any maps in the list atm only the 25,45,75.
45 1.8 auto Connie 50k
25 Streetwise 54k
620 SLI Honda 60k
Yaris & C3
Kriss707
Re: Hybrid turbo
#3 Post by Kriss707 » Mon Mar 04, 2019 7:46 pm
I have had very good results tuning my 1998 2.2dt Espace by simply replacing the airbox with a quality cone filter, fitting a single box straight through stainless steel exhaust & blocking off the EGR valve. Admittedly the vehicle wasn't fitted with a cat from the factory. The emissions are fine for M.o.T.
The turbo lag has reduced as the turbo now spins freely and sounds great, The Mrs is a bit of a Trafficlight Grand Prix-er, she has left many a boy racer for dead, much to our amusement. The look on their faces as a People Carrier blows them away is hilarious.
If you listen to some of the Land Rover boys they reckon to turn up the diesel pump for more power. I would imagine on a modern diesel this would need to be done by re-mapping.
A wise old engineer once told me. . . .the quicker you get the gasses in & out, the quicker the engine turns, the quicker you go !
