Rover 416-Auto with honda singlecam engine/Power steering
ukbiker1000
#1 Post by ukbiker1000 » Wed Aug 14, 2019 6:57 pm
Hi All
Since buying my 400 in 2017, the power steering is heavy, I remember 216 gti i have long time was really nice and light enough to enjoy driving. But this 400 not so fun. its just stiff.
-I have changed to tyres, it made very very little improvements.(Tyre PSi is correct)
-Power steering fluid changed with no improvements.
Next steep is all wheels alignment and tracking checked. I am not sure if this will make steering lighter
Does anyone notice this issue, my mate who's had 2 400 rovers said they all have stiff steering. can this be sorted?
D
Re: Rover 416-Auto with honda singlecam engine/Power steering
#2 Post by 1234dist » Wed Aug 14, 2019 7:32 pm
when you put the new ps fluid in, and ran the engine did you see the fluid move actively?
Is the steering at all juddery when going lock to lock or steering quickly?
ukbiker1000
#3 Post by ukbiker1000 » Wed Aug 14, 2019 8:25 pm
After fluid was put in and engine, run, all was ok, mechanic was doing this, so i did not really see or notice fluid move actively. he said process was ok,
driving and turning is smooth, it is just stiff, its like 50% power steering better than non power steering system. All i know for sure is it should be alot lighter than current.
belt is tension is good, everything appears to be working ok, yet this power steering just a little better than having non.
so far i have compared to 3 other rover 416 owned by friends, 2 were just as bad as mine, 3rd one (saloon version was a little better).
D
The Origina lNom
#4 Post by The Origina lNom » Thu Aug 15, 2019 6:00 pm
Would swapping the two front upper wishbones a la ZS180 to give more camber help ?
that would reduce the size of the tyre contact patch when at a standstill.
#5 Post by GTiJohn » Fri Aug 16, 2019 12:37 am
Either the pump isn't generating sufficient pressure, the rack is leaking the generated pressure internally without it being used to turn the wheels or something is resisting the forces generated.
The last one is probably the easiest to check - jack the front of the car up, and with the engine off, see if you can move either front wheel from one lock to the other. You should be able to move it fairly easily and smoothly. If not you need to investigate the ball joints first and the steering rack second.
The other two potential problem areas will require some in-line pressure measurements which is a bit tricky.
ukbiker1000
#6 Post by ukbiker1000 » Sun Aug 18, 2019 3:38 am
I must try something eitherway. shall start with easiest.
D
#7 Post by Mr Teddy Bear » Tue Sep 17, 2019 5:34 pm
My 400 has heavy steering compared to a 216. I've put that down to 15 inch wheels/tyres though! Certainly not unpleasantly heavy imo.
If the power steering isn't working properly it will be really noticeable when parking, especially if you don't have the car moving going from lock to lock! :D
A manual rack is only really heavy when parking imo, that was with 14" lattice wheels mind, 15" s would be worse I would expect?
