Rust Proofing
Club Secretary
Rust Proofing
#1 Post by Paul_1978_yorks » Sat Jan 14, 2017 9:19 am
I want undertake as much rust proofing as I can on my 416 this year.
I'm ok with undersealing the arches etc, but as for "injecting sills" - what do you use and what are your injection points?
Any other general tips of this nature will I'm sure be of mutual interest to all owners :-)
Re: Rust Proofing
#2 Post by crepello » Sat Jan 14, 2017 10:21 am
You'll find various blanking grommets sealing access points to box sections, unless a repairer has plated them over. The most visible ones being low down at the front of the rear wheel arches. I used these to squirt Waxoyl in using their long tube, but I've no idea how effective the spray pattern was. The technique was to insert it all the way, then slowly retract while squeezing the trigger.
More recently, I've noticed that age has made the blanking grommets stiffer and somewhat brittle. I've been looking for replacements, but such that I have found are designed with a narrow groove for flat sheet apertures, not the rounded/drawn edge given to ours.
Re: Rust Proofing
#3 Post by 220 GSi turbo » Sat Jan 14, 2017 7:13 pm
As above,
Plus:
Remove the kick plates from the sills, you can use the screw holes for additional access into the sills.
remove the interior lamp switches from the pillars, that gives you entry to the B post and part of the rear wheel arch area.
On 4 and 5-door cars it is easy to remove the small plastic rubbing strip thing from the rear wheelarch and that gives you another access point into the arch and sill.
Removing the boot lamp gives access to the top and rear end of the wheelarch on that side of the car.
remove the boot seal at the bottom (by the latch), rust often starts on the lip there.
I have used Bilt Hamber products on our cars and have had no cause for complaint yet :)
1995 220GSi Turbo: owned for 17 years
Club Secretary
Re: Rust Proofing
#4 Post by Paul_1978_yorks » Sat Jan 14, 2017 9:16 pm
Brill, thanks guys :-)
prepace
Re: Rust Proofing
#5 Post by prepace » Sat Jan 14, 2017 9:45 pm
Great advice...........I'll be tackling that job on both cars over the coming months
Re: Rust Proofing
#6 Post by GTiJohn » Sun Jan 15, 2017 9:39 am
Related to this, regular cleaning out of all the cack that gets behind the rear of the front wheel arch liners is a good idea.
Most of it is usually leaves so after autumn is probably the best time.
JEASPEKE
Re: Rust Proofing
#7 Post by JEASPEKE » Thu Jan 19, 2017 7:50 pm
Waxoyl goes in better if you stand the can in a bucket of hot water for 30 mins or so, otherwise, it has a jelly-like texture at Uk temps.
John Anfield
Club Secretary
Re: Rust Proofing
#8 Post by Paul_1978_yorks » Thu Jan 19, 2017 11:15 pm
Good tip John :-)
g259fsg
Re: Rust Proofing
#9 Post by g259fsg » Mon Jan 30, 2017 8:28 pm
I agree, it's best to spray the Waxoyl when it's quite liquid. Warming it up in cold weather is useful, but for spraying I usually dilute it with around 30 to 50% white spirit. I apply it with the Waxoyl pressure sprayer and extension for box sections. I spray the whole underside of the car with it, really fast. It's very effective and the stuff will go into every nook and cranny, and the white spirit dilution means it flows easily even in cold weather. The white spirit soon evaporates and leaves the Waxoyl all over. Another place to check for corrosion is behind the plastic mudflaps at the back of the front wheel arches if you have these fitted. They attach with three crosshead screws. I've found quite a lot of muck behind there - think it comes down through a drainage channel. Definitely worth cleaning that out and Waxoyling.
JEASPEKE
Re: Rust Proofing
#10 Post by JEASPEKE » Mon Jan 30, 2017 8:54 pm
Even better :clapping
Club Secretary
Re: Rust Proofing
#11 Post by Paul_1978_yorks » Mon Jan 30, 2017 10:35 pm
Loving all the tips. Can't wait for some spring weather now to get stuck in!
Re: Rust Proofing
#12 Post by 1234dist » Tue Jan 31, 2017 8:27 am
As we all know, my black coupe has been a LLLLLLOOOOOONNNNNNGGGGG project.
(I've been fixing everyone elses) :angel
So during this year project most of the work completed on the car has been that of rust proofing. Seeing as i got the car shell for free (bar collection from southampton) this project currently stands at £2250. :slapme
The shell was picked up due to being completely rust free (and black) and have since done that much rust proofing and sound proofing i'm almost confident the car could now float.
If you are serious about stopping rust you do need to be prepared to go back to bare shell and build yourself up. The hardest part is not just spraying waxoil everywhere but remembering the drainage points in the doors ect.
The other issue i had was when i'd done arch liners and behind the wings was it was soooooo shiny :unsure
Re: Rust Proofing
#13 Post by ROVER-25X » Thu Feb 02, 2017 9:55 pm
Get one of these and a cheap air compressor. ;)
I got it for a rust/panel repair on my old MGF, going to use it on the Cabby. :D
ROVER-25X (2001 1.4 ROVER 25)
ASTRA TwinTop 1.9CDTi
Re: Rust Proofing
#14 Post by 1234dist » Fri Feb 03, 2017 12:53 am
i still have pics of that grind and fill session, even knowing what we did to it, i still bought it off you. :slapme
So much rust and weld on my shop floor from your cars... :glare
Club Secretary
Re: Rust Proofing
#15 Post by Paul_1978_yorks » Fri Feb 03, 2017 9:31 am
ROVER-25X wrote:Get one of these and a cheap air compressor. ;)
Good idea - will any air compressor gun fit on an aerosol like that or do you need an adapter of some sort?
