Cabrio rear window
cryptogram
Cabrio rear window
#1 Post by cryptogram » Mon Jun 17, 2019 8:52 am
How do you remove this?
Re: Cabrio rear window
#2 Post by GTiJohn » Mon Jun 17, 2019 9:51 am
This video should help - about 11.40in
https://www.youtube.com/watch?v=7nslNea-mwY&t=1297s
cryptogram
#3 Post by cryptogram » Mon Jun 17, 2019 10:53 am
Thanks GTiJohn. However, this video explains how to get the whole roof off rather than just the rear window. I believe this is meant to unzip but I haven't been able to see how.
rbosworth2016
#4 Post by rbosworth2016 » Mon Jun 17, 2019 12:35 pm
The original roof had a removable rear window. If your roof has been replaced by a previous owner, they may have installed a softtop with an integrated window which does not come out. :sad
Richard
cryptogram
#5 Post by cryptogram » Mon Jun 17, 2019 4:01 pm
No, I have owned the car from new, so I imagine I can get it out.
Kriss707
#6 Post by Kriss707 » Mon Jun 17, 2019 8:34 pm
If you look in the Cabriolet specific section, there's a thread headed Hood Refitting.
I've posted on the thread how to remove the rear window section.
#7 Post by 961tat » Mon Jun 17, 2019 10:38 pm
Pull the window down from the inside at the top ,, there should Velcro at the top and sides of the window , the zip should be at the top under the Velcro, then undo screw on the bottom rail under rubber seal . if no zip it's a one piece hood and replace the back window the hood will need taking of the frame .
cryptogram
#8 Post by cryptogram » Wed Jun 19, 2019 8:48 pm
Thanks kriss
The Origina lNom
#9 Post by The Origina lNom » Sun Sep 08, 2019 2:41 pm
I have an original very low use cabriolet rear window if you need it ?
cryptogram
#10 Post by cryptogram » Fri Sep 13, 2019 4:53 pm
Thanks, but I've now got the whole caboodle.
