420GSI tourer mini restoration
N1tr0_9
#1 Post by N1tr0_9 » Sat Sep 12, 2020 8:27 pm
Dear all, i am about to shamelessly copy and paste my project thread from retrorides, since it involves a green 420 gsi i bought with front end damage.
I think the previous owner Simon B was on this here forum so some of you will recognise the car. Ive stuck a few things on facebook, but thought i would copy it here too.
James
We begin the copy and paste fest...
I really suck at not buying cars. To be fair this one isn't really my fault. All I intended to do was buy a gearbox with LSD in it for my bubble project, but when I turned up I sort of ended up buying this.
Its a 1995 420 gsi tourer. I remember trying to get my Dad to buy one as a replacement for the family Montego estate, but he said it was too small. Probably right in hindsight. Still cool though.
This car was a much loved car that was pretty well known. It was slightly modified with 16" Cosmos alloys (similar to BRM), lowered 60 mm, Roversport bumpers, big brake conversion and mk1 bonnet and grille. Here it is with previous owner Simon in a magazine article. Photo was taken at Pride of Longbridge.
Unfortunately a foreign taxi driver got a roundabout a bit wrong causing the car ahead of Simon to emergency stop. Being a modern SUV thing, it stopped fast, whereas the Rover didn't and ended up a bit bent. However luckily the Rover was so low it under-ran the rear of the SUV and the damage is all at a high level and confined to just the bonnet, slam panel, bonnet latch and headlights. Better news is that there was no damage to the SUV and the damage to the Rover is unrecorded.
Simon was going to break it up. He removed and sold the sport bumpers, and it now wears the original suspension rather than lowered. I got to keep the cosmos alloys, mid level custom tailgate spoiler and Simon gave me a spare mk2 bonnet and front bumper and headlights.
Here it is in all its glory.
Interior is excellent apart form a bit of side bolster wear. Being a GSI it has Recaro style seats with half leather.
This is the damage
Chassis rails are perfect. Just the slam panel moving back has tweaked the panels either side of the rad rearwards at the top.
Already started pulling it out by hand
Had a spare radiator already that came with the bubble. Just need to fit the rad fan and sensors.
N1tr0_9
Re: 420GSI tourer mini restoration
#2 Post by N1tr0_9 » Sat Sep 12, 2020 8:27 pm
N1tr0_9
#3 Post by N1tr0_9 » Sat Sep 12, 2020 8:28 pm
Had a very productive day.
Simon, the previous owner has supplied me with all the parts needed to fix it! That includes a chopped section from the front of a donor car.
I spent the day pulling out the remainder of the rearward crushing, and then picking the slam panel off the donor car and the bent one off my car and then checking the alignment.
Had to unbolt the top and front of the front wings to get to some of the spot welds. Not difficult though.
Then with the old slam panel off i could do the final shaping of the support mounts.
Balanced the new slam panel on and put the wings back in place.
Simon gave/lent me a standard mk2 bonnet (no 2.0 gsi bulge) so i trial fitted that to make sure the new slam panel worked with the bonnet latch. All works fine. So now i just need to prep the panel and weld it on.
Also check out the history file. Proper old school wallet think with labelled front. Then inside pretty much every MOT, loads of handwritten invoices and service notes. Fantastic!
#4 Post by RoverRevival » Sat Sep 12, 2020 8:29 pm
:groupwave
Watching
25 Streetwise 54k
25 IL 36k
216 ronda coupe
620 SLI Honda 60k
& C3
N1tr0_9
#5 Post by N1tr0_9 » Sat Sep 12, 2020 8:31 pm
:groupwave
Watching
"Forum says no" It now one let me post anymore, think maybe it thinks im flooding it with spam??
#6 Post by RoverRevival » Sat Sep 12, 2020 8:36 pm
5 min between posts
25 Streetwise 54k
25 IL 36k
216 ronda coupe
620 SLI Honda 60k
& C3
N1tr0_9
#7 Post by N1tr0_9 » Sat Sep 12, 2020 8:43 pm
5 min between posts
Ahh i did wonder. Seems to like plain text but not links to pictures or video?
#8 Post by RoverRevival » Sat Sep 12, 2020 8:46 pm
Just post a link, it will probably be blocked code from the other site or advertising links ect that jumla blocks.
25 Streetwise 54k
25 IL 36k
216 ronda coupe
620 SLI Honda 60k
& C3
Cthomas
#9 Post by Cthomas » Sat Sep 12, 2020 11:11 pm
Nice to see you here James. I’ve watched the sd1 police car on Matt’s YouTube
Rover 216 vdp 1990
Old ones
Rover 216 vdp 1986 my dads last car
Rover 420 gsi 1992 miss this one
Rover 214 sei 1995
Rover 820
Rover 3500 vp sdi
Rover 2600 sdi
N1tr0_9
#10 Post by N1tr0_9 » Sun Sep 13, 2020 9:21 am
Yes that was a result. He also did a road test of this car.
N1tr0_9
#11 Post by N1tr0_9 » Sun Sep 13, 2020 9:22 am
Attempting to work my way quite speedily through this car.
Been sorting the water pipes at work while its too dark or too wet to weld the front on (or basically I'm too tired after work)
N1tr0_9
#12 Post by N1tr0_9 » Sun Sep 13, 2020 9:53 am
Put them in the blast cabinet, but its not really up to the job so i used a strip and clean pad on a grinder. Much better.
N1tr0_9
#13 Post by N1tr0_9 » Sun Sep 13, 2020 9:53 am
Then i found some splits that needed welding up. Think the tube is made of flat, that is bent into a curve and welded and it slit along the weld, so i cleaned it off and welded it back up.
N1tr0_9
#14 Post by N1tr0_9 » Sun Sep 13, 2020 9:53 am
Then found some grot behind a bracket so opened it up and used a hacksaw to clean it up. Then left them to soak all weekedn in Bilt Hamber Deox C rust killer.
N1tr0_9
#15 Post by N1tr0_9 » Sun Sep 13, 2020 10:05 am
Painted the lower hoses in bona primer and then black.. Top rail didi in etch and tehn black.
