Rover 216 s series alternator replacement
Use this board for any non-technical 200 or 400 related topic including motorsport, trivia, insurance matters etc.
Liam.d
#1 Post by Liam.d » Sun Oct 25, 2020 7:14 pm
Hi iv got to replace the alternator on the rover which way is easier to get it out top or bottom ?? Iv only had a quick look tonight from the top an there’s not much room I’m guessing it’s easier out the bottom ? Cheeeeers
Cthomas
Re: Rover 216 s series alternator replacement
#2 Post by Cthomas » Sun Oct 25, 2020 7:17 pm
I would do it from the bottom
Rover 216 vdp 1990
Old ones
Rover 216 vdp 1986 my dads last car
Rover 420 gsi 1992 miss this one
Rover 214 sei 1995
Rover 820
Rover 3500 vp sdi
Rover 2600 sdi
Liam.d
#3 Post by Liam.d » Sun Oct 25, 2020 7:39 pm
Is there anything in the way underneath that I need to remove I.e a pain to get off etc ?
Cthomas
#4 Post by Cthomas » Sun Oct 25, 2020 9:10 pm
I don’t think so. I’ll have a look in the morning and tell you how I would replace it
Rover 216 vdp 1990
Old ones
Rover 214 sei 1995
Rover 820
Rover 3500 vp sdi
Rover 2600 sdi
Liam.d
#5 Post by Liam.d » Sun Oct 25, 2020 9:17 pm
Ok thanks much appreciated
Cthomas
#6 Post by Cthomas » Mon Oct 26, 2020 11:29 am
You need a 13mm socket, 10mm socket, ratchet, 17mm spanner, lever bar and 13mm spanner. You should have a clip holding the plug in the back of alternator then undo 13mm bolt at the bottom of alternator, loosen the 17mm bolt on engine and undo the top bolt then it should come out. car still has the under tray that bolts on the bumper so that needs to be removed if still on your car to get alternator out the bottom
Rover 216 vdp 1990
Old ones
Rover 214 sei 1995
Rover 820
Rover 3500 vp sdi
Rover 2600 sdi
Liam.d
#7 Post by Liam.d » Mon Oct 26, 2020 5:42 pm
Thanks for that but looking at it properly in daylight the whole loom about a foot up has rotted all 3 wires on the plug too to the extent the wires have dropped off the plug so looks like I need a alternator loom or see if I can strip it all back and replace the wires also do you know where I can get the black plug for the alternator?? Cheers
Cthomas
#8 Post by Cthomas » Mon Oct 26, 2020 6:16 pm
Rover 216 vdp 1990
Old ones
Rover 214 sei 1995
Rover 820
Rover 3500 vp sdi
Rover 2600 sdi
Liam.d
#9 Post by Liam.d » Mon Oct 26, 2020 6:54 pm
Thank you I’ll order that now an all I have to do is solder it in instead of them bullet connectors
Liam.d
#10 Post by Liam.d » Mon Oct 26, 2020 6:55 pm
I might need to get a wiring diagram of which way the wires go in the plug as there’s nothing left on mine an I can’t tell
Cthomas
#11 Post by Cthomas » Mon Oct 26, 2020 7:41 pm
The two big red wires need too be connected to the old wires or starter/battery. The small wire goes too the battery light on dash
Rover 216 vdp 1990
Old ones
Rover 214 sei 1995
Rover 820
Rover 3500 vp sdi
Rover 2600 sdi
Liam.d
#12 Post by Liam.d » Mon Oct 26, 2020 7:47 pm
Ahhhh ok pretty straight forward then I’m hoping there’s a bit of good loom left for me to solder in this new bit of loom if not it’ll have to be replaced to both starter and alt an then really hoping here the little wire is good so I don’t have to trace back to the clocks but thanks for your help you’ve been a life saver :D
Cthomas
#13 Post by Cthomas » Mon Oct 26, 2020 7:50 pm
I’ll have a look 2mor and tell where it connects
Rover 216 vdp 1990
Old ones
Rover 214 sei 1995
Rover 820
Rover 3500 vp sdi
Rover 2600 sdi
Liam.d
#14 Post by Liam.d » Mon Oct 26, 2020 9:22 pm
Thanks much appreciated
#15 Post by 220 GSi turbo » Mon Oct 26, 2020 10:51 pm
Unless you have already got one, I would suggest you don't commit to buying a new alternator until the wiring has been repaired.
The old one may actually still work when it has good wiring connected to it again.
Daily: ZR Trophy TD
