Practical Classics Restoration Show, NEC Birmingham, 31 March-2 April 2017
Car Ownership: Rover 220 Turbo Hatchback
Postby 220 GSi turbo » Wed Dec 21, 2016 9:46 pm
We're in! :clapping
A 9m x 4.5m stand in Hall 7 has been allocated to us, so it is time to get planning.
Watch this thread for more details :wink3
gbs100
Car Ownership: Rover 214 Hatchback
Re: Practical Classics Restoration Show, NEC Birmingham, 31 March-2 April 2017
Postby gbs100 » Wed Dec 21, 2016 11:27 pm
Well done. :clapping best start making some plans.
Car Ownership: Rover 420 Turbo Saloon
Postby 1234dist » Thu Dec 22, 2016 11:08 am
Need to get to the nec at leased once :laughing2
Coupe Project K785OAT (abs fixing again :cool )
220 Coupe now barely a shell :rip
prepace
Car Ownership: Rover 416 Saloon
Postby prepace » Thu Dec 22, 2016 10:34 pm
:D Good news, looking forward to it
Current Rover
1990 'H' R8 416 GSi - White
1998 'R' R8 416 SE Tourer - Charcoal
2002 75 2.5 V6 Connoisseur - Wedgewood Blue
Car Ownership: Rover 216 Cabriolet
Postby cabriolet106 » Sat Dec 24, 2016 4:59 pm
Should be able to make it on the Sunday.
Car Ownership: Rover 216 Coupe
Postby GTiJohn » Sat Dec 24, 2016 6:15 pm
Good that we're starting to see the support we'll need over the weekend. :clapping
The basic idea is that we'll be resurrecting an early, high-spec but currently forlorn R8 216 GSi that Simon Boosey found and has secreted away 'till March. The challenge will be to get it back to looking its best and sorting out some (relatively minor) mechanical jobs on it.
We can probably only fit 2 cars on the stand so we have to decide what to do in the other space - either an 'after', shiny car or another one of our cars needing a bit of TLC.
Get your proposals in early!
(We can't weld, spray, leak or pollute and it's a good idea if we don't disable a car in the process :wink3 )
Club Committee
Car Ownership: Rover 216 Hatchback
Postby StubbornPatriot » Mon Dec 26, 2016 11:46 am
Are we still considering having my knackered K16 engine (from the Tourer) on the stand for a strip down? If so, I need to prioritise swapping the engine out.
Cheers,
Duncan
Nigel B
Postby Nigel B » Wed Dec 28, 2016 7:04 pm
Great news that we have a stand, was a little worried when Simon had bought the car, think the use f the 2nd car space for the engine makes sense to me, body shop one side, engine shop the other.
Happy to help on either of the days, if needed
:clapping :horn
Kieran94
Regular Member
Car Ownership: Other Rover
Postby Kieran94 » Mon Jan 02, 2017 11:45 pm
I was speaking with Simon about this resto car a little while back... cannot wait for more info, it looks a brilliant car!
beef
Postby beef » Sat Jan 07, 2017 11:00 pm
if you would like an engine on the stand again iv got a std 220gti M16 engine that could be used
Postby GTiJohn » Sun Jan 08, 2017 11:52 am
beef wrote:if you would like an engine on the stand again iv got a std 220gti M16 engine that could be used
We might have space for it - would you be 'doing stuff' on it? This show is more 'doing' than 'polishing' :D
Regarding the 216GSi resto (Simon's car), I've been in touch with Rimmers to see if they'd help us with parts and I'll approach some cleaning products companies to see if I can get them to help too.
The parts list is currently:
Driver's door mirror - elec, black early type
Service items for a Honda 1.6 - plugs,belts, filters, oils, wiper blades etc
Exhaust manifold gasket
Centre caps for 14" lattice alloy wheels
Battery
Brake pads and we may need to look at the rear calipers
If anybody can donate any of the above it would reduce our 'ask' from Rimmers .
The seams on the leather rear seat are also coming apart, as they always do. I know a good local leathersmith who's into his classic cars that I'm sure I could get to come to the show to repair this if we give him a ticket.
It's coming together ! :D
Postby GTiJohn » Sun Jan 08, 2017 12:29 pm
Here are some 'before' pictures - these are after Simon B retrieved the car and with nothing having been touched
I have a spare cam cover that I'll repaint to replace this one.
Simon says ( :slapme ) the ALB light comes on AND GOES OFF!
beef
Postby beef » Sun Jan 08, 2017 10:15 pm
yes mate the engine is in need of a rebuild
Car Ownership: Rover 414 Saloon
Postby Mr Teddy Bear » Mon Jan 09, 2017 12:57 pm
If the plane is to change the cam belt make sure who ever is doing it can remove the crankshaft pully bolt. Cus it's tight :cursing !
I have a electric Clark knock knock gun, but I haven't tested it against such a formidable opponent as that bolt. Book gives a figure of 140 foot lbs I believe . I suspect it ain't coming off without using the factory flywheel locking tool.
As the D16 is a Jap engine and runs backwards I have wondered if it's a left hand thread? :slapme I expect that one of Beef, Dist John or Paul can answer this question?
Rover 216 GTi Flame Red 1992
Rover 414Si British Racing Green 1995
Rover 216GTi TC Ocean Blue 1993
Postby 1234dist » Mon Jan 09, 2017 1:06 pm
nope its a normal tread.
righty tighty, lefty loosy
:wink3
recommend tighten slightly first (if you can) but only a little.
and don't forget
Return to “Events and Meetings”
Who is online
Users browsing this forum: No registered users and 2 guests
