Headgasket
Re: Headgasket
#16 Post by ROVER-25X » Wed Apr 10, 2019 1:47 am
Your mechanic is an idiot. :glare
ROVER-25X (2001 1.4 ROVER 25)
ASTRA TwinTop 1.9CDTi
Vinny1979
Re: Headgasket
#17 Post by Vinny1979 » Fri Apr 12, 2019 9:23 am
1234dist wrote:
Tue Apr 09, 2019 6:46 am
Start with the easy fix first, the cap is a common fault and can cause all the issues you have listed so far.
Absolute worst case, even if it’s hgf it’s £100 in parts and 2hrs to fix, and a skim if needed.
Rover dave
Re: Headgasket
#18 Post by Rover dave » Sat Apr 13, 2019 10:10 pm
Hi , I had thought pouring this stuff into my engine maybe a bad move :unsure but I thought I would get other people`s opinion`s first . Replaced cap Tuesday but pushed out coolant last night :headbanging and slightly more brown stuff in expansion tank , but oil filler cap and dipstick still clean and no overheating ? :S
Re: Headgasket
#19 Post by crepello » Sat Apr 13, 2019 11:46 pm
Is coolant circulating as it should be? That is if you start from cold and idle until warm, do you feel heat creeping across the radiator, and is there a dribble through the small return hose to the header tank?
Re: Headgasket
#20 Post by 1234dist » Sun Apr 14, 2019 6:55 am
Thermostat next port of call, still a nice easy fix you can do your self with just an 8mn socket.
Rover dave
Re: Headgasket
#21 Post by Rover dave » Mon Apr 15, 2019 8:38 pm
Yep thermostat next , twice the car has taken longer than normal to get up to temp maybe sticking thermo ? . Would this cause the expansion tank to overflow ? . Anybody heard of or used a Headgasket testing kit you use on the expansion tank ie place a bung into the top of tank with a tube coming out of bung partly filled with a blue dye ,run the car until warm if any exhaust gases pass through into tube blue dye turns green thus telling you the Headgasket has gone .Its something I heard today . Is it just a myth? Ive never heard of this .
Re: Headgasket
#22 Post by 1234dist » Mon Apr 15, 2019 8:49 pm
yes it reacts with the exhaust gases in the water.
Sticking thermos would cause blow backs in the bottle due to not putting water through the radiator to cool it.
Rover dave
Re: Headgasket
#23 Post by Rover dave » Mon Apr 15, 2019 9:52 pm
Many thank`s :) thermostat it is then , what`s the best way of avoiding any airlocks when refitting thermostat ?
Re: Headgasket
#24 Post by Mr Teddy Bear » Mon Apr 15, 2019 11:05 pm
Don't drain the heater; so turn the heat to cold. Run it with the expansion tank cap off from cold & watch the level.
Then take it for a short run, wait till hot, then plenty of revs, let it cool and check the level, then keep an eye on it fo r the next week or so.
216 GSi Auto Pearlescent Cherry Red 1991
Re: Headgasket
#25 Post by 1234dist » Tue Apr 16, 2019 6:43 am
You are taking a pipe out of the middle of the cooling system, no, you'll get air locks.
Rover dave
Re: Headgasket
#26 Post by Rover dave » Fri Apr 19, 2019 11:17 am
Ok , thank`s .
Rover dave
Re: Headgasket
#27 Post by Rover dave » Sat May 04, 2019 4:52 pm
Update , new thermostat fitted system bled through 8mm bleednut coolant clean and no air bubbles, temp gauge ok heater hot no overheating , oil clean . But bottom hose and expansion tank hoses cold ! :headbanging Headgasket test done with test kit you fit to expansion tank colour did not change after 1/2 hour . Also can anyone advise me on what brake fluid I need to top up with . DOT 4 mineral or DOT 4 synthetic ? .Thanks . Rover 214si 1993
Re: Headgasket
#28 Post by crepello » Sat May 04, 2019 8:38 pm
As the bottom hose is the return from the radiator, I'd be quite pleased if mine was cold!
Can you feel heat creeping across the radiator as the engine comes up to temperature?
The pump should be generating just enough head to produce a dribble of flow from the small return hose between the top hose and the expansion tank.
Rover dave
Re: Headgasket
#29 Post by Rover dave » Sat May 04, 2019 9:03 pm
Hi , sometimes you see a small dribble from the small return hose , sometimes you don't see any .
Re: Headgasket
#30 Post by JOHNDQ » Sat May 04, 2019 9:28 pm
Get a PRT thermostat on there :)
