214 SPI fails MoT on CO emissions
clayts450
#1 Post by clayts450 » Thu Jul 04, 2019 3:21 pm
K540WRP failed MoT on emissions, on CO : fast idle 0.48% (max 0.30%), second fast idle 0.52% (max 0.30%), natural idle 1.81% (max 0.75%).
Lambda fine (1.02 on fast idle, 1.00 on second fast idle),
Hydrocarbons fine (117 ppm, max 200 on fast idle; 74ppm max 200 on second fast idle).
I suspect the cat is shot and this was what the tester was leaning towards. What do we think ?
1992 Rover 214 SLi
1994 Rover 420 SLi
1996 Rover 620 Si Auto
1999 Honda Accord Coupe 2.0i ES
2004 Rover Streetwise S
Re: 214 SPI fails MoT on CO emissions
#2 Post by 961tat » Thu Jul 04, 2019 4:12 pm
Nook it back in Take it for a blast down to motorway and drive it like it's stolen before it retested , if that fail disconnect camcover breather pipe from the cam cover and bock up . First one works for me the engine as to be red hot and second one worked year ago on a 216 that had piston ring trouble. :D
richard moss
#3 Post by richard moss » Thu Jul 04, 2019 7:04 pm
It could also be a problem with the coolant temperature sensor as this can cause K-series with mems to run rich
clayts450
#4 Post by clayts450 » Thu Jul 04, 2019 10:05 pm
Should add, the car has had the following new items fitted in the last 6 months or so:
  • coolant temperature sensor
    air intake temperature sensor
    spark plugs
    HT leads
    rotor arm
    dizzy cap
    oil filter and oil change
    air filter
    fuel filter
    line from fuel trap to ECU cleaned out
    all breathers/lines checked and replaced where needed
    front exhaust section (incl flexi)
1992 Rover 214 SLi
1994 Rover 420 SLi
clayts450
#5 Post by clayts450 » Fri Jul 05, 2019 5:46 pm
New cat put on by my good self, just waiting on a re-test probably early next week now
1992 Rover 214 SLi
1994 Rover 420 SLi
#6 Post by 1234dist » Fri Jul 05, 2019 6:42 pm
Cat additive and an Italian tune will get that figure down.
marshall1
#7 Post by marshall1 » Sun Jul 07, 2019 10:24 pm
Cabby failed emissions, quick' Italian Tune' to 'warm up the Cat' and it passed ok.
Had a Fiesta that had the same issue, failing emissions several years. Then they started doing emissions test as soon as I took it in after a hard run and it passed. Sitting at idle while they poked about underneath just let the Cat lose its efficiency.
clayts450
#8 Post by clayts450 » Mon Jul 08, 2019 10:06 pm
Agreed, if I get up early enough tomorrow, I'm gonna lob a few litres of Shell petrol and some Cataclean in there for good measure, and then give it a razz down the M1 in 3rd/4th for a junction or two, before rocking up at the test centre.
1992 Rover 214 SLi
1994 Rover 420 SLi
clayts450
#9 Post by clayts450 » Thu Jul 11, 2019 9:14 am
Gotta pass this morning, well happy.
So, new cat, bottle of Cataclean, Italian tune up, testing station ready and waiting with the exhaust probe.
Emissions this time ?
Fast idle CO NIL
Natural idle CO NIL
Bingo bango :)
1992 Rover 214 SLi
1994 Rover 420 SLi
#10 Post by 1234dist » Thu Jul 11, 2019 3:02 pm
:S
Nil
Was the probe plugged in?
Best I’ve ever had was 0.2 of the 0.3 max
clayts450
#11 Post by clayts450 » Thu Jul 11, 2019 7:35 pm
Yup, NIL.
The tester said to me 'yeah, it's just squeaked past'. I asked him what the readings were and he smiled and showed me.
HCs were 29 so it was definitely working.
I suppose when you combine new barely used cat, 15 litres of petrol, a bottle of Cataclean and an Italian tune up it is entirely possible !
Craig - do you have T4 ? I might need your services with this one. Er, and possibly a new clutch.
1992 Rover 214 SLi
1994 Rover 420 SLi
#12 Post by 1234dist » Thu Jul 11, 2019 8:43 pm
No to the t4 but can defo do the clutch and pretty good at diagnosis once I can see it.
clayts450
#13 Post by clayts450 » Thu Jul 11, 2019 10:36 pm
Thanks, much appreciated - I'll ping you a PM shortly.
It'll probably be a few weeks before I can come to yours (214 being willing of course !) as I'm booked up for the next two weeks with work, parts collections for various members of my fleet and the Festival of the Unexceptional !
1992 Rover 214 SLi
1994 Rover 420 SLi
#14 Post by 1234dist » Fri Jul 12, 2019 8:07 am
Replied :cool
