1989 216 no spark
Goodwoodmm
1989 216 no spark
#1 Post by Goodwoodmm » Wed Oct 02, 2019 6:41 am
Could anybody point me in the right direction with a no spark issue on my 216. Have replaced coil, crank sensor, leads, distributor cap and Ecu but still nothing!!! Thanks.
Re: 1989 216 no spark
#2 Post by GTiJohn » Wed Oct 02, 2019 7:40 am
Is this an S-series 216 saloon or a D-series 216 hatchback? '89 could be either...
Club Secretary
#3 Post by StubbornPatriot » Wed Oct 02, 2019 8:27 am
When did the problem start? Has it been running recently? Did you fit a new rotor arm when you changed the distributor cap?
1989 216GSI + 1990 216GSI + 1997 416 Tourer + Triumph T160V
#4 Post by 1234dist » Wed Oct 02, 2019 8:53 am
If Honda, it’s your distributor
#5 Post by GTiJohn » Wed Oct 02, 2019 9:47 am
That where I was going but it may not be a D :wink3
richard moss
#6 Post by richard moss » Wed Oct 02, 2019 5:20 pm
Often a problem, often missed
Goodwoodmm
#7 Post by Goodwoodmm » Wed Oct 02, 2019 6:17 pm
Thanks for all the replies. NOT Honda and a saloon. Nothing from the coil, power in and out but no HT.
Goodwoodmm
#8 Post by Goodwoodmm » Wed Oct 02, 2019 6:30 pm
#9 Post by GTiJohn » Wed Oct 02, 2019 7:07 pm
Have you got a 'known good' coil you can try? You might be unlucky and have fitted a duff or incorrect one.
#10 Post by 220 GSi turbo » Wed Oct 02, 2019 7:24 pm
Do you know if you have a 12v (ish) supply to the coil when the ignition is turned on?
Also, check all of the fuses carefully: it is very likely that the main 12v supply to the ECU is fused and if that fuse has blown, the ECU will do nothing.
Is it a carburettor-fed engine, or fuel injection (EFi)?
The whole ignition and fuel system on your car is very similar to that used on the Maestro and Montego, so if anybody else reading this has access to an M&M manual, perhaps they can offer some help :)
1995 220GSi Turbo: owned for 18 years
Daily: ZR Trophy TD
Goodwoodmm
#11 Post by Goodwoodmm » Wed Oct 02, 2019 7:55 pm
Thanks for the reply. It’s a carburettor engine. 12v both sides of the coil. Seems to have power to the ecu.
Kriss707
#12 Post by Kriss707 » Thu Oct 03, 2019 12:15 am
This is a primative way of testing the Coil in situ .... If you connect the Coil + & - direct to the battery + & - then turn the engine, if there's a spark the problem is before the coil. Depending on your electrical system the car may even start this way so make sure its not in gear.
If there's no spark your Coil is duff.
Goodwoodmm
#13 Post by Goodwoodmm » Wed Oct 09, 2019 10:24 pm
Still can’t seem to get a spark. Any other thoughts or suggestions?
#14 Post by crepello » Thu Oct 10, 2019 9:05 am
Is there an electronic igniter amplifier module on the distributor?
On my K8's distributor, this has failed in the past, resulting in no spark.
Goodwoodmm
#15 Post by Goodwoodmm » Sat Oct 12, 2019 8:58 am
Thanks. Will have a look 👍
