420 GSi Turbo ECU same as 220 GTi Turbo ECU?
Club Secretary
#1 Post by StubbornPatriot » Wed Jan 12, 2022 10:38 am
Quick question - Anybody happen to know whether a 420 GSi Turbo ECU is the same as the 220 GTi Turbo ECU? I don't have access to the 220 GTi Turbo to check the ECU ID. Thanks, Duncan.
Re: 420 GSi Turbo ECU same as 220 GTi Turbo ECU?
#2 Post by RoverRevival » Wed Jan 12, 2022 12:57 pm
same engine same car, similar year should all be the same
Plenty of parts for sale @ www.roverrevival.co.uk
#3 Post by 220 GSi turbo » Fri Jan 14, 2022 2:01 pm
The only difference I can think of is that later cars (1994 model year) had the Lucas 5AS alarm/immobiliser and the engine ECU will be expecting a 'disarm' signal from the 5AS unit before it will work.
I think it can be 'programmed out' of the later ECU using the EKA code (if the donor car is still 'alive'!) or using TestBook.
1995 220GSi Turbo: owned for 20 years
Daily: 25 D
#4 Post by RoverRevival » Fri Jan 14, 2022 2:05 pm
just cut pin 13
Vinny1979
#5 Post by Vinny1979 » Fri Jan 14, 2022 5:08 pm
They are different
Club Secretary
#6 Post by StubbornPatriot » Fri Jan 14, 2022 9:34 pm
Thanks for the replies guys - much appreciated. This came up on E-bay and I was considering getting it as a spare but I'm probably better off finding out what the ID is on my ECU and keeping an eye out for an identical one some time in the future. Cheers, Duncan.
#7 Post by 961tat » Fri Jan 14, 2022 10:33 pm
Hello Duncan why don't you email https://www.technozen-electronics.co.uk ... -services/
Club Secretary
#8 Post by StubbornPatriot » Fri Jan 14, 2022 10:50 pm
Hi Chris. The ECU that's in it is OK. When things come up on Ebay (or elsewhere) that I think might be useful in the spares department, I quite often buy them, if they're a reasonable price (although I'm going to need a very BIG shed soon). Cheers, Duncan.
rjessett
#9 Post by rjessett » Sat Jan 15, 2022 1:01 am
Always worth doing. Certainly with ECU's as they are something I think we will never be able to reproduce. The good thing is Rover did a decent job on MEMS and its pretty bullet proof.....
Im starting a plan to stock up on all ECU's for all variants. Create a bit of a library for them (and be able to pair them all)
#10 Post by 961tat » Sat Jan 15, 2022 8:55 am
Hello Duncan was thinking more about the compatibility of the two items seeing hes into ECU etc have you fitted that crossmember yet ?
Cheers Chris
