Brake pipe different size fittings
Vinny1979
#1 Post by Vinny1979 » Sat Apr 13, 2019 11:26 am
So gone to look at my new master cylinder and I have noticed that the rover 220 fitting that goes into the master cylinder is bigger than the holes on the 300 tdi master cylinder,
what do I do?
Julesmat50
Re: Brake pipe different size fittings
#2 Post by Julesmat50 » Sat Apr 13, 2019 11:54 am
what do I do?
2 choices. Either cut off the 220 fitting, get the correct sized fitting for the 300 master cylinder and re-make the brake pipe with the new sized fitting or see if you can get an adapter that will fit both the master cylinder and your existing union. Probably the easiest would be to simply saw off the flare of the existing pipe, swap the fitting for one of the correct size and re-flare the pipe. Brake pipe flaring kits are not that expensive if you have to buy one and are endlessly useful for all your brake pipe needs :D
Vinny1979
#3 Post by Vinny1979 » Sat Apr 13, 2019 12:11 pm
I have never flared a pipe before, I imagine its easy?
#4 Post by RoverRevival » Sat Apr 13, 2019 12:44 pm
get some pipe and play before doing it live.
216 ronda coupe
& C3
Vinny1979
#5 Post by Vinny1979 » Sat Apr 13, 2019 4:20 pm
There is a guy in town who will do the two lines for about £20
I have got them remvoed now, took a bit but the shape is pretty much there.
Would have been easier with the engine out :laughing2
#6 Post by ROVER-25X » Sun Apr 14, 2019 2:37 am
At least you found someone to save you an effort.
Vinny1979
#7 Post by Vinny1979 » Wed Apr 24, 2019 6:32 pm
Got these fitted guys
The fittings were m10 and m12
I have ran 2 new lines from the land rover 300 tdi master cylinder to the abs modulator
hoping this has cured my issue of not being able to bleed brakes
for anyone interested it cost me £15 delivered for two lengths of 64" brake line which is ideal for the job
it was a pain to do in situ but looks very neat imo
more to follow
#8 Post by GTiJohn » Wed Apr 24, 2019 7:08 pm
Photos please - we've got to fit a new modulator Jeremy's No.1 sometime soon.
Vinny1979
#9 Post by Vinny1979 » Wed Apr 24, 2019 9:01 pm
ok :)
