Indicators needing to 'warm up' to work
edie_fox
#1 Post by edie_fox » Fri Jan 03, 2020 10:59 am
Hi
Apologies if this is in here, I did have a search first.
My car is booked in for electrical bits and bobs but I like to try and have everything available for the guy when I take it in save going back and forth.
Has anyone experienced this before, is it common? The indicators need to warm up before they will work correctly....which isn't great as I can't open my window to manually indicate either until it goes in for the work!! Relay/terminal/fuse or....what?
If anyone knows what it is and it's a simple fix...do link me if it is as simple as a 'part' on Rimmers or wherever. I'll be popping back there in the next week.
Thank you :) (my 'help' posts will reduce with time! :laughing2 )
1994 216SLi - Bronze (it's gold though, innit)
1990 Volvo 480 Turbo
Past Rovers:
J 218 SD - Large snail.
J 420 ? - Loved.
R 416 - awful!
Kriss707
Re: Indicators needing to 'warm up' to work
#2 Post by Kriss707 » Fri Jan 03, 2020 7:40 pm
Check all the connections, including the bulbs & holders, are clean & the relay is 'clicking' solidly.
A lot of bulb/lighting problems are caused by poor earthing.
Are the Hazard lights slow too ?
#3 Post by 1234dist » Fri Jan 03, 2020 9:41 pm
My money would be the relay
#4 Post by richard moss » Sat Jan 04, 2020 3:37 am
Possibly broken solder joints inside the relay. It's a common fault on, for example, the ECUs of Honda powered Rovers of the 80s and 90s
