Rover 216 SE starting issues
7thFebfree
#1 Post by 7thFebfree » Thu Feb 13, 2020 5:07 pm
thanks for your response , it’s definitely a Honda engine
Cromp85
Re: Rover 216 SE starting issues
#2 Post by Cromp85 » Thu Feb 13, 2020 5:48 pm
Is you engine Honda or Rover?
They both use different ignition systems so it will help to confirm which one.
1995 214i (On SORN)
#3 Post by GTiJohn » Thu Feb 13, 2020 6:25 pm
216SE = SD3?
if so, it's an S-series...
Cromp85
#4 Post by Cromp85 » Thu Feb 13, 2020 7:38 pm
216SE = SD3?
Good point, I took 216 SE as meaning R8 SEi :slapme
Unfortunately I dont have any knowledge of S series engines. At a guess, i would think the electrics are more related to the late Maestros & Montegos.
1995 214i (On SORN)
#5 Post by 220 GSi turbo » Thu Feb 13, 2020 11:04 pm
I would assume that a 216 SE would be an SD3, so as mentioned by others here, it will be the S-series engine as also used in the Maestro and Montego.
I can't remember if all SEs were fuel injected (Lucas EFi, like the MG Maestro 2.0) or if some of the earlier ones had a carburettor.
Could you clarify what you mean by "firing, but not starting"?
If it is an EFi system and the engine runs for a second and then stops, it is likely to be caused by one of the fuel pump relays.
Daily: ZR Trophy TD
#6 Post by 220 GSi turbo » Fri Feb 14, 2020 8:46 pm
Having just read your edit to your original post stating that it is a Honda engine, I guess your car must be an 'R8' after all.......maybe a 216 SE cabriolet?
Hopefully one of our Honda experts will be along soon :wink3
Daily: ZR Trophy TD
#7 Post by richard moss » Sat Feb 15, 2020 4:09 am
If it IS a Honda engine, then the obvious starting point (sorry) is inspecting the inside of the main relay unit for broken solder joints and resoldering them.
Actually, it's worth resoldering them all anyway
JEASPEKE
#8 Post by JEASPEKE » Sat Feb 15, 2020 10:30 pm
I wrote an article on testing the main relay in an issue of the Viking 2016 or 17 probably, have a look at back issues
#9 Post by 1234dist » Sun Feb 16, 2020 7:32 am
Happy to offer this service if you send me the relay and return post.
