Broken seat height adjuster
MGZRreplica
#1 Post by MGZRreplica » Mon Apr 06, 2020 11:02 am
Has anybody fixed seat adjuster.
The seat rocks backwards and forward.
Anybody got any advice?
Or a detailed drawing?
Grey 220 coupe
BRG 216 SLi
Silver 1.8vvc coupe-Sold
BRG 1.8 diesel-Sold
Silver 25GTi-Sold
BRG 200vi-Sold
Silver 200vi-Sold
K-reg White 216GSi-Sold- Started the ❤️
A-Reg Blue 1litre Metro - Scrapped💔
Re: Broken seat height adjuster
#2 Post by 220 GSi turbo » Mon Apr 06, 2020 8:39 pm
I will check my (factory) workshop manual when I get the chance, it should have instructions on how to take the covers off, so it might also mention the height adjuster.
If that fails, I have a spare Rover 25 seat in the garage that I can have a look at and see if that gives any clues on how it all works. I would think it probably works in a similar way to a car scissor jack.
Daily: ZR Trophy TD
MGZRreplica
#3 Post by MGZRreplica » Mon Apr 06, 2020 9:16 pm
Thanks.
Looking forward to your reply.
I suppose you should be able
to change it.
Grey 220 coupe
BRG 216 SLi
BRG 1.8 diesel-Sold
Silver 25GTi-Sold
BRG 200vi-Sold
Silver 200vi-Sold
#4 Post by 220 GSi turbo » Tue Apr 07, 2020 4:58 pm
OK, assuming you have the height adjuster that is operated by a small handle under the front of the seat (not a lever on the side, which was used on 1990-93 R8s), it is exactly how I thought it was when I posted last night.
Effectively a screw jack, so the handle drives a threaded rod in and out of a tube and this acts on some levers to move the seat up and down.
If the seat is rocking, it will be either a problem with the pivots between the levers, or the nuts and screws that hold the seat to the mechanism may have worked loose.
If you remove the whole seat from the car and turn it upside down you will be able to see what is going on.
As the seat is screwed to the mechanism, you should be able to replace just the mechanism with one from any 200, 25, ZR etc.
If it would really help, I could take my spare seat apart and get a few photos.....
Daily: ZR Trophy TD
#5 Post by 961tat » Tue Apr 07, 2020 7:20 pm
Got one here already out will post pictures tomorrow :D
#6 Post by 961tat » Wed Apr 08, 2020 1:33 pm
MGZRreplica
#7 Post by MGZRreplica » Wed Apr 08, 2020 4:32 pm
I’ve took the seat out the bar
at the front has split both sides
Grey 220 coupe
BRG 216 SLi
BRG 1.8 diesel-Sold
Silver 25GTi-Sold
BRG 200vi-Sold
Silver 200vi-Sold
MGZRreplica
#8 Post by MGZRreplica » Wed Apr 08, 2020 5:55 pm
I’ve got a basic seat base which is
non-height adjustable or no seat belt
tensioner.
Grey 220 coupe
BRG 216 SLi
BRG 1.8 diesel-Sold
Silver 25GTi-Sold
BRG 200vi-Sold
Silver 200vi-Sold
