220 turbo loss of power
engtmitc
Re: 220 turbo loss of power
#16 Post by engtmitc » Tue Nov 16, 2021 8:12 am
RoverRevival wrote:
Tue Nov 16, 2021 7:50 am
When was the fuel filter last changed?
Not changed since the restoration which was just over 12 months ago.
not GONE
engtmitc
#17 Post by engtmitc » Wed Nov 17, 2021 6:29 am
Anyway, garage say the fuel pressure test was done after the fuel filter so would already take that into account.
Now focus is on ECU/sensors (as when you switch off the fault goes away for a while then comes back) so garage trying to find/adapt the wiring loom to recreate the 800's fault code reading socket...as I am advised that during the restoration a 220 wiring loom could not be found so a 620/820 one was used which was adapted.
not GONE
4V8s
#18 Post by 4V8s » Mon Nov 22, 2021 9:57 pm
Sounds like the ignition timing is out, or the cams. Something like that. I'd imagine if so, lambda reading may be well off?
How about fuel filter?
Rover 214Si 16v 1994
Rover 220 turbo coupe 1995
Rover Mini Cooper 1997
1977 Pontiac Firebird 403 V8
