Body Trim Panel Contact Tape
#1 Post by ROVER-25X » Sun Feb 11, 2018 11:17 am
I noticed on my interior panels and rub strips that they
have a thin strip of one sided contact tape, I just had a
quick look on Rimmers but I can't find any, can anyone
recommend a replacement as I was just going to use
some 6mm foam tape but it all seems to be double
sided, I could always leave the backing tape on the back.
ROVER-25X (2001 1.4 ROVER 25)
ASTRA TwinTop 1.9CDTi
Kriss707
Re: Body Trim Panel Contact Tape
#2 Post by Kriss707 » Wed Feb 28, 2018 7:36 pm
Hi,
If it is a film like double sided tape, pop to any motor factor/car paint supplier such as Morelli, Mill Auto etc & ask for 3M-6506 Refix tape.
Cromp85
Regular Forum User
#3 Post by Cromp85 » Wed Feb 28, 2018 10:57 pm
If you mean the thin black tape that stops the squeaks from where Interior trim butts together, I think it's called 'Felt tape'. Im after some myself but i have no idea who sells it.
My Rovers to date:
1995 214i (On SORN)
#4 Post by Johnny 216GSi » Wed Feb 28, 2018 11:50 pm
Single-sided foam tape - you need to look on Ebay or suppliers like RS components, Rapid electronics, Farnell, etc. They do a *huge* range. I've been buying a mix of foam tape and neoprene rubber strips off Ebay. I'm using a high-temperature double-sided 3M adhesive tape but I also find the GT Pro / Ultratape double-sided tape a good way of making one side adhesive and it is extremely sticky.
It's a matter of using your imagination - anything is possible - even say a thin sheet of waterproof fabric, polyester or acrylic felt and a double-sided adhesive tape on the other side to make it sticky. I don't have any hard-and-fast rules and I've used lots of different combinations.
#5 Post by ROVER-25X » Sun Mar 04, 2018 7:46 pm
Right I just had a look on ebay chaps, that M3 tape doesn't really look like what I need but I found felt tape.
China special, 15 metres long for a couple of quid: https://www.ebay.co.uk/itm/15m-Car-Vehi ... SwoYhaJoRL
UK Anti-Squeak Tape, 25mm wide and 500mm long: http://www.ebay.co.uk/itm/ANTI-SQUEAK-A ... Swy1NaXl5f
Might get both.
