Small update:
Whilst waiting for the roll cage to return, I made a start putting everything back together, refitting the pedal box, steering column and also the heater matrix system I sourced over Christmas from Ian Mann.
Reading the Roversport manual, I will need to trim some of the plastic away on the heater matrix in order for the cage to refit
I’ve also made a start sorting out the wiring loom for the car which although functional, it was a complete mess
Im basically stripping back all the insulation, trunking and then removing redundant wires from the body loom - ABS system, fog lights, radio etc.
A lot of wires were also hidden or cut which I plan to reuse/rewire in due course, such as horns, washer motor for front windscreen, heater matrix, rear heated screen.
Looks scary work, but it’s not too difficult to do. I’m labelling all plugs as I go along and then I’ll be test fitting the loom to the car before reinsulating.
Big thanks to CoupeRich for helping me identify some of the plugs on the loom 8)
