The ROVER-CX8 Cabriolet Project
Re: The ROVER-CX8 Cabriolet Project
#46 Post by ROVER-25X » Sat Feb 10, 2018 8:29 pm
What are you after the dark panels, the leathers or both ?
Aaronrover214cab1993
#47 Post by Aaronrover214cab1993 » Sat Feb 10, 2018 8:50 pm
Mainly the dark panels and a dash board
Seats would be a bonus though
#48 Post by ROVER-25X » Sat Feb 10, 2018 11:49 pm
Loads of bubble dashboards about, i'll be using one out of a ROVER 25 donor car, the Mk2 25/ZR one would look different in an R8,
the squarer lines would suit it, wiring is a little bit of a pain and you need the Mk2 Air Box too as the internal/external air is switch
operated but not too hard.
#49 Post by 1234dist » Sun Feb 11, 2018 7:21 am
I have a black mk3 dash :wink3
#50 Post by Aaronrover214cab1993 » Sun Feb 11, 2018 8:48 am
I'm wanting to keep the older type dash board to be honest I have always preferred these as it's one of the things I like be about them I think there such a good looking dash board and make a great mug holder or shelf :clapping
#51 Post by ROVER-25X » Sun Feb 11, 2018 10:46 am
Cup holders are easy. :wink3
#52 Post by ROVER-25X » Tue May 01, 2018 4:29 am
(SORT OF) UPDATE
Nothing much to report, few more parts acquired, the ECU in order to run an OEM MAP sensor
and a front Strut Brace, asides that the car is still turning green but at least it survived the
winter, just got to wait a few months for the garage to be built and organised then I can give
it a jet wash and park it up in a nice dry place ready to be restored.
#53 Post by ROVER-25X » Tue Aug 07, 2018 9:18 pm
MINOR UPDATE
The car is now on all four wheels after being up in the air for over a year on an axel stand, I have given up on
the Turbo Brakes that won't fit as I could get no answers from anyone so I bit the bullet and bought a bargain
set of ZS180 Calipers and they came with as near as makes no difference new Brembo Pads and Discs, former
owner rebuilt and repainted them, they have done less than 1000 miles, made up and the car is back to a
drivable state although it will fail an MOT. :laughing2
"Whats the plan ?"
"Plan ? there ain't no plan !"
Car has been sat that long its turned into a haunted house. :laughing2
The hubs got a scrub.
Old and new discs, slight difference in size.
First Caliper fitted.
Should stop the 1.8 Turbo well once its fitted.
New 16" Streetwise Alloys fitted.
Put a battery on and it started fine, left it to get up to temp, fan kicked in, happy days, no more
plans for it yet as it is waiting for the new garage to be built to get it out the weather.
#54 Post by 1234dist » Wed Aug 08, 2018 6:31 am
:laughing2
Looks like spiderman had a crafty W**k in there :slapme
Aint nowt new looking about those alloys, and the tyres have a smoother surface area than Steve... :laughing2
Vulgalour
#55 Post by Vulgalour » Sat Aug 11, 2018 3:40 pm
Those Streetwise alloys look really good on there.
Current Fleet:
1994 Rover 414 SLi
#56 Post by ROVER-25X » Sun Aug 12, 2018 12:50 pm
#57 Post by 1234dist » Sun Aug 12, 2018 1:11 pm
:mouthshut
#58 Post by Johnny 216GSi » Sun Aug 12, 2018 3:25 pm
That web is thicker than my quilt. Is there a special Manc spider up there? I'm never clearing out your shed again if it's as big as that web suggests it is. I'd just buy another R8 if I found a web that large in mine, rather than negotiate with the occupant and lose...
#59 Post by ROVER-25X » Mon Aug 13, 2018 9:41 pm
I still haven't seen the spider making the home in mine, no doubt it'll nibble my bum when i'm stripping it. :laughing2
#60 Post by ROVER-25X » Sat Apr 06, 2019 4:30 pm
FINALLY, A sort of UPDATE !
I now have the donor car for this long drawn out Cabby project. :clapping
It is a ROVER 25 1.6 Impression S, it will not only be a parts bearer for the 3 other 25's in the family fleet
but it will also be offering the following items up for the Cabby.
MEMS3 Wiring Loom (Already have a 1.6 Auto ECU for the Turbo Conversion Map Sensor setup)
Full A/C system, I may replace the Condenser if it is too rough but all the Pipes and Mounts will be converted.
The ABS System, converting to a 1.8 Turbo will need additional braking, ABS seems a good addition when it is wet.
Additional wiring for the Alarm and ABS System.
The Dash and all its trims as I am removing the beige bubble dash and going with a dark interior. (Possibly the only dark late dash Cabby ?)
Plus additional miscellaneous items.
