Rover 420i cutting out when cold.
Calvert_87
#1 Post by Calvert_87 » Mon Nov 05, 2018 7:09 pm
Its developed its first fault after two trouble free months! Its ran a bit lumpy for the first few minutes on the first drive of the day since I picked it up. Its fine after that and after sitting for 8 hours in work car park also fine. But the last 3 mornings its cut out outside exactly the same house round the corner from me. Ive know its going to happen even if I keep the revs up in second I can feel it loosing power and it cuts out. Also becomes difficult to start again but eventually does then is spot on the rest of the day. Any ideas? Cheers in advance, Andy.
Calvert_87
Re: Rover 420i cutting out when cold.
#2 Post by Calvert_87 » Mon Nov 05, 2018 7:13 pm
Sorry forgot to add its a 2.0 t series nasp.
#3 Post by Paul_1978_yorks » Mon Nov 05, 2018 8:41 pm
I’ve had a similar problems with my T series, but not to the point of cutting out.
However I have done the following:
* Cleaned throttle body with carb cleaner.
* Removed and cleaned vacuum pipes.
* New plugs/leads.
Much better now. One thing that I also want to do, because mine is hesitant when cold, especially in cold weather, is replace the coolant temperature sensor. I saw somewhere that this can also give these symptoms, but I haven’t got round to doing it yet.
Let us know how you get on. :)
1996-N Charcoal 214 SEi (off the road)
214 SEi x3
216 SLi
216 Cabriolet
416 GSi
25/45/75
Calvert_87
#4 Post by Calvert_87 » Tue Nov 06, 2018 12:51 pm
Hi thanks for the advice. It didn't do it this morning was fine although it was an unusually warm for 5:30am on a Novembers morning today! The three bullet points have been done by the previous owner around 2000 miles ago. (1000 by him and I have done a 1000 since getting it, this is the car in question in this thread https://www.rover200.org.uk/forums/view ... =2&t=12206 The owner documented and dated a list of work that he did to re-commission it including the bullet point suggestions. No mention of a new coolant temperature sensor though. Has anyone got the part number for this please. I have had a look on rimmer bros and cant find it. Cheers Andy.
#5 Post by Mr Teddy Bear » Tue Nov 06, 2018 4:02 pm
I would give it an Italian Tune Up; a regular shot of fuel injection cleaner and only fill up at a BP/SHELL/ESSO pump.
Clogged injectors might not be the only issue you have, does the engine hunt on start up? or is it cutting out after 5 minutes say?
Try opening the throttle slightly as you turn it over.
Calvert_87
#6 Post by Calvert_87 » Tue Nov 06, 2018 4:59 pm
Hi, I will try the fuel injector cleaner as well. Only gets filled up with v power like all my cars, habit of mine always had performance cars, got a 335i atm as well as run arounds so end up putting vpower in the lot ha. No idles perfect. Cuts out after 60-70 seconds but I know soon as its in gear whether or not its going to cut out. Have started pressing the throttle on start up. Have to do that with the the maestro turbo but that's carb not fuel injection. Although its the same block, good old rover!
Calvert_87
#7 Post by Calvert_87 » Tue Nov 06, 2018 7:02 pm
Had another look there for coolant temp sensor, looks like the part number is ADU7161 and fits every austin/rover ever made from maestro o series to 200 k series. Has anyone ever had any problems for the cheaper ones from eBay? Ail fit one see if cures the problem.
https://www.ebay.co.uk/itm/Lemark-Coola ... :rk:1:pf:0
clayts450
#8 Post by clayts450 » Thu Nov 08, 2018 7:34 pm
This seller has OE CTS in a Land Rover bag - ordered Tuesday, delivered and signed for today:
https://www.ebay.co.uk/itm/Genuine-Aust ... :rk:1:pf:0
1992 Rover 214 SLi
1994 Rover 420 SLi
1996 Rover 620 Si Auto
1999 Honda Accord Coupe 2.0i ES
2004 Rover Streetwise S
Calvert_87
#9 Post by Calvert_87 » Fri Nov 09, 2018 7:31 am
Ordered the cheaper one a few days back. I will report back after a week or so to tell if there are any improvements. Noticed that this week its only done it twice and that's when I have had the heating on from starting to demist the windows. when I haven't needed to demist the windows it hasn't. Still running lumpy and lack of power till warm though.
richard moss
#10 Post by richard moss » Sun Nov 11, 2018 8:45 pm
Coolant temperature sensor is often a good bet - but so is the rotor arm. Many are poor quality and short out after running for a while. They get warm, short circuit and then die but function properly again when they cool down.
Of course that doesn't apply if you have one with the twin coil pack, rather than a distributor, and doesn't really sound like your problem.
When was the fuel filter last changed? Do you park on a slope which may cause sludge/dirt to build up in a fuel line?
Just stabbing in the dark there, really
Calvert_87
#11 Post by Calvert_87 » Wed Dec 05, 2018 8:48 am
Well its been long enough now and had enough cold mornings to say touch wood but the coolant temperature sensor has fixed it! Hasn't cut out since the new one was fitted nearly a month back. Still a bit lumpy for the first few minutes but I can live with that.
#12 Post by Paul_1978_yorks » Wed Dec 05, 2018 5:59 pm
That’s good to hear :)
I just might do my sensor anyway!
214 SEi x3
216 SLi
216 Cabriolet
416 GSi
25/45/75
