Which head gasket to use
G.Watts
#1 Post by G.Watts » Mon Jan 20, 2020 2:11 pm
Hi everyone my 2006 rover 45 k series has had HGF after removing the head I checked the liner heights and found they were only 0.05mm above the block there are quite a few opinions on which gasket to use. I would like to use the mls gasket but I’m not sure my liners are high enough your thoughts on this would be greatly appreciated
Re: Which head gasket to use
#2 Post by 1234dist » Mon Jan 20, 2020 3:36 pm
I would use an oe elastomer gasket on that.
#3 Post by itcaptainslow » Mon Jan 20, 2020 3:37 pm
This, definitely.
Rover 200 BRM
Rover 214SEI
#4 Post by crepello » Mon Jan 20, 2020 4:23 pm
Others may disagree, but I'd be happy with one similar to this BGA one:
While this is often described as a MLS gasket, I tend to think this is a misnomer, as there is only a single steel layer, and the black layers are polymer mouldings. Being sheets, much less prone to bursting than the original beads.
I think the restrictions on liner height variation must be due to the reduced flexibility of the 'true' MLS gaskets, with multiple steel laminations, from Land-Rover, however the one shown above retains the same single flat steel layer with crushable fire rings used in the initial k-series design, so should match it for flexibility.
I used the BGA on a 214 I bought with HG issues. It hasn't had much use since, but the job looks OK so far.
#5 Post by JOHNDQ » Mon Jan 20, 2020 10:01 pm
Shim liners and use the latest Victor Reinz 61-34835-20 with built in head saver or the SIAC gasket from Xpart/discount MG Rover spares.
G.Watts
#6 Post by G.Watts » Tue Jan 21, 2020 1:25 pm
Thanks to everyone for their comments,I’m going to order the elastomer gasket dmgrs sell one which is supposedly better than the rover original so fingers crossed.As I’ve got the head removed I thought it would be a good idea to change the thermostat does anyone have a suggestion as to the best one to get thanks again Gordon
#7 Post by itcaptainslow » Tue Jan 21, 2020 2:31 pm
OE original, get a complete housing as they’re prone to leaking when disturbed.
Rover 200 BRM
Rover 214SEI
#8 Post by 961tat » Tue Jan 21, 2020 7:56 pm
Put a blank in the old housing and use a PRT .
https://ibb.co/myh4jVb
#9 Post by itcaptainslow » Tue Jan 21, 2020 10:06 pm
Or that-forgot about those!
Rover 200 BRM
Rover 214SEI
#10 Post by GTiJohn » Wed Jan 22, 2020 8:13 am
PRT?
Pray tell :D
#11 Post by 1234dist » Wed Jan 22, 2020 8:17 am
What the more modern k-series used to get rid of the terrible bleeding coolant system of early k-series.
Pressure release thermostat, almost self bleeding.
A great upgrade to those who frequently change coolant. Relatively cheap upgrade, main cost is the new pipes but the thermostat it’s self does fail regularly (or at least mine did).
G.Watts
#12 Post by G.Watts » Wed Jan 22, 2020 1:47 pm
Thanks for your comments I’ve not heard of the PRT so I may go down that route,is there a blanking plug and seal available?
#13 Post by 961tat » Wed Jan 22, 2020 4:03 pm
You just get you old stat and take out the middle and put it back in will look for a picture .
#14 Post by JOHNDQ » Wed Jan 22, 2020 6:37 pm
If you want to avoid HG failure again fit the PRT thermostat unfortunately it is a bit of a fiddly job especially if you have the R65 box as starter is in the way and the difference in the pipe diameter from the PRT to the lower radiator pipe
G.Watts
#15 Post by G.Watts » Wed Jan 22, 2020 7:23 pm
My car is a 1.4 so I think it has the R65 box, rimmers list a complete PRT kit so I was hoping it was a simple bolt on job
