Rover 25 Facelift Headlight Glass... Plastic
The Origina lNom
#1 Post by The Origina lNom » Tue Jan 01, 2019 7:25 pm
Just happened across a facelift 25 with separation of the headlight glass from the body.
The inside of the plastic? is filthy what should i use to re-seal the headlight after cleaning ?
Thanks in advance.
Re: Rover 25 Facelift Headlight Glass... Plastic
#2 Post by 1234dist » Tue Jan 01, 2019 7:38 pm
a dustbin and just replace them, they are to cheap to faf around with
JOHNDQ
#3 Post by JOHNDQ » Wed Jan 02, 2019 12:00 am
Yes reseal with high temp black RTV sealant the MK2 lights are expensive to buy new about £150 from euros. Just make sure to remove all the original sealant first
The Origina lNom
#4 Post by The Origina lNom » Wed Jan 02, 2019 1:57 pm
Thank you. I knew the cost of replacing them would be exhorbitant.
JOHNDQ
#5 Post by JOHNDQ » Wed Jan 02, 2019 2:59 pm
That's trouble with the MK2 as only made for a year some parts hard to get and or expensive
#6 Post by Johnny 216GSi » Wed Jan 02, 2019 4:30 pm
I've used Sikaflex 291 black marine-grade sealant to good effect where I've needed to seal mechanical parts and metal-to-rubber interfaces whilst rust-proofing. Seems very sticky and tough once cured, and does the job. Marine grade, so salt-water resistant and designed to stop corrosion. Designed for boat hulls, so should keep headlights watertight for a long time (after you've cleaned them and got them bone try of course).
Bought mine in the 300ml caulking gun tube, so you'll need the caulking gun too - or another method of neatly applying the stuff as it can get messy.
#7 Post by ROVER-25X » Sun Jan 06, 2019 8:55 pm
I used windscreen sealer/adhesive to seal up my 200 bubble headlights.
ROVER-25X (2001 1.4 ROVER 25)
ASTRA TwinTop 1.9CDTi
